Grrrrr. rear hatch
Old Dec 11, 2019 | 08:13 AM
Richard Sawkins's Avatar
Richard Sawkins
Default Grrrrr. rear hatch
So, the rear hatch has started acting up. You use the key or the dash button and the hatch pops just a little, then sucks itself back down again. Takes 10 to 20 attempts to open it. Its only a 2016 so the gas struts should still be good, and in fact they lift the hatch with no problem. Anybody else had this, and if so, what fixed it?
Old Dec 11, 2019 | 09:00 AM
I Fly Low's Avatar
I Fly Low
I will look at mine later, but it seems there is a switch/sensor out of adjustment. Hopefully it is a quick fix.
Old Dec 11, 2019 | 09:03 AM
RWDonly's Avatar
RWDonly
When others have mentioned this problem on the forum the fix was to lubricate the weather stripping for the hatch (generally a dielectric type of grease is used for this purpose) to prevent it from sticking to the body of the car. If that doesn't fix it... perhaps it's a problem with the latch itself needing some adjustment?
Old Dec 11, 2019 | 09:24 AM
Maxpowers's Avatar
Maxpowers
Yup. I have to use a silicon spray every other month when the temps get cooler. The weather stripping sticks.
Old Dec 11, 2019 | 09:30 AM
Lubricating the weatherstripping is certainly a cheap and easy first step to solving the problem. If that doesn’t work, then look at other possibilities. Good luck and hope you can avoid a trip to the dealer.
Old Dec 11, 2019 | 10:54 PM
agapsdiver's Avatar
agapsdiver
Before you open the hatch.. crack a window or open the door to relieve interior pressure so it doesn't suck back down.
Old Dec 12, 2019 | 11:08 AM
JMII's Avatar
JMII
This worked for mine. I would hit the button, it would unlock but not pop up enough to get your fingers under to lift up. Once the weather stripping was cleaned and greased it popped right up. In fact the dielectric grease has worked so well I have not needed another coat in over a year. My 2014 doesn't have the power pull down so once it unlocks you are more or less forced to figure out a way to open it since you need to slam in back down (with the doors open) to make it lock down again. Very annoying
Old Dec 12, 2019 | 12:04 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Baby oil for weatherstripping
Old Dec 12, 2019 | 01:56 PM
RWDonly's Avatar
RWDonly
Here are the official part numbers from the owner's manual.
Old Dec 12, 2019 | 02:08 PM
geraldschumann's Avatar
geraldschumann
3634770 may be discontinued or GM changed the part number. I bought some a couple years ago and it works great but for some reason the stuff is high as cats back. Around $50!
Old Dec 12, 2019 | 02:10 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
I used to spray all my seals with Silicon spray until I used this stuff:
Gummi Pflege Stift' Rubber Care Stick
Amazon Amazon
Old Dec 12, 2019 | 02:14 PM
RWDonly's Avatar
RWDonly
I would imagine any dielectric grease should be fine. I actually use Honda ShinEtsu dielectric grease because there is still a ton of it left in the $10 tube that I bought years ago for my S2000.
Old Dec 12, 2019 | 02:21 PM
geraldschumann
I think there are a lot of good products out there however I am superstitious. Yes yes I know, it’s bad luck to be superstitious! That’s why I went with the super expensive GM rubber treatment. If something doesn’t work then you will know because you will be buying new weather stripping. Oh but to have the magic Corvette crystal ball...
The good experiences and input is what makes this forum great!
To Grrrrr. rear hatch
