Windshield replacement Q:
Old Dec 15, 2019 | 10:54 PM
Maxie2U's Avatar
Maxie2U
Originally Posted by 16/C7Z
Have you looked into a product like clearplex?
I had that installed on my 19 when picked up (2 weeks after it was built). Like a sacrificial skin that can be peeled and replaced for about 400.
Much less intrusive than having the windshield torn out. I have free glass replacement but f those complications. Money well spent imo.
Does Clearplex provide a warranty against chips and cracked windshield that they will pay for the windshield replacement if clearplex fails to stop either?
Old Dec 15, 2019 | 11:14 PM
Maxie2U's Avatar
Maxie2U
Originally Posted by twoweeled
My 2019 is just weeks old. I've come to realize, the windshield is a FREAKIN rock magnet!! I'm pretty sure it's just a matter of time. Was it an easy issue overall? Did you stay with GM OEM? If not, was the replacement just as good with HUD and all. How much? Lotta questions I know, but a general idea of what to expect and avoid?
Thanks!
Unfortunately most new model car & SUV windshields chip or crack very easily because manufacturers have significantly reduced the weight of the windshield because traditional windshield are very heavy and they are looking to remove as much weight from the car as possible.
And Yes, I stayed with the GM HUD because I have a $100 deductible and I talked to a couple people who got aftermarket windshields who said their HUDs were blurry so I did not want to chance it. Full disclosure others have said they had no issues with aftermarket windshields
The most important aspect about having the windshield replaced is making sure the auto replacement tech has actually replaced a lot of C7 windshields. I called my Corvette dealer and asked them who they used. They told me they used the same guy again and again that he had replaced at least two dozen C7 windshields. They even gave me his number so I got to speak with him directly. He was the guy who also replaced my 2nd windshield after it completely cracked after a large rock hit it.
Old Dec 27, 2019 | 03:58 PM
RiCorvette's Avatar
RiCorvette
Originally Posted by c54u
Add to your cart, check out and type in your Zip and shipping would be $10-$15
https://www.gmpartsgiant.com/parts/g...-84367842.html
The annoyance and Irritation continues. I ordered the Part on the 17th and is still hasn't shipped.
I called several times and finally today was told the order will be cancelled because the $15 shipping charge is too low.
GM Parts Giant seems to be a Broker like Amazon and sources stuff from various dealers.
Grrrrrrr!
Old Dec 27, 2019 | 05:19 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by RiCorvette
My Windshield was replaced under warranty (Delamination) and I have a Leak - the Dealer and their Glass Subcontractor have looked at it twice and say there is nothing they will further do to remedy the problem. Other posts here have opined that the Weather Stripping Seal Gasket is easily damaged during removal / replacement, and should have been replaced with a new one. I did not see the P/N for it listed in the Work Order or Receipt
The Weatherstrip Rubber Seal/Gasket covers the Top and A Pillars - The leak is inside the car that starts at the top of the inside A Pillar Trim. The Windshield sealing itself seems to be Good. It is the Weatherstrip Rubber Seal/Gasket that seems to be the culprit.
I am trying to build a case that the Weatherstrip Rubber Seal/Gasket ( P/N 84367842 ) should have been replaced and would like to know if the GM Service Manual specifies this as SOP when the Windshield is replaced
Had a similar issue with my C5Z replacement windshield. The installer tried to stop the leak by using RTV but just made it worse. Finally had to get State Farm involved (they paid for the replacement glass) to get any resolution. SF approved a new windshield installation with the weather strip that went up the A pillar and along the side of the top. That stopped the leak. Had the second replacement done at the dealer's shop with their body guy checking over the work done by the contractor. The dealer body guy had 25 plus years experience working on Corvette Bodies and knew all of the proper sealing techniques.
Bill
Old Dec 27, 2019 | 05:33 PM
RiCorvette's Avatar
RiCorvette
Chasing a Chimera, it seems.
All these "GMPARTSXXX.com' Websites seem to be brokers, not actual Retail/Wholesale Companies with stock.
