Fuel cutoff switch?
Old Dec 27, 2019 | 11:36 AM
2Laidback's Avatar
2Laidback
Default Fuel cutoff switch?
I had an accident on track and have the car back ready to start but...seems like no fuel is getting to the engine. Driver's airbag did go off. Car will turn over but not actually starting. I have searched all over the web/forum and cannot figure this out. I just want to start her up! It's been since April! Way too long.
Old Dec 27, 2019 | 03:06 PM
Am interested in what you find out.
Old Dec 27, 2019 | 03:11 PM
Avanti's Avatar
Avanti
Have you been able to check other potential sources of "stoppage" such as damaged lines, etc?
(btw, there should be a fuel-pump relay to check, as well)
Old Dec 27, 2019 | 03:29 PM
2Laidback's Avatar
2Laidback
No damage to fuel. I'll double check the relay. All was good before I hit the wall, lol. Front end only damage.
Old Dec 27, 2019 | 05:50 PM
Bill Dearborn's Avatar
Bill Dearborn
Remove battery ground and positive cables and touch them together and then reconnect and see what happens.
Bill
Old Dec 27, 2019 | 06:01 PM
Maxpowers's Avatar
Maxpowers
Bill - I always trust your judgement. But can you clarify on this one?
Old Dec 27, 2019 | 07:30 PM
DavePowell's Avatar
DavePowell
That will reset the various computers.
Old Dec 27, 2019 | 08:04 PM
2Laidback's Avatar
2Laidback
Tried touching the wires together for about 30 seconds. Nothing different.
Old Dec 28, 2019 | 03:38 PM
stefuel's Avatar
stefuel
Guessing it probably has to do with the air bag or restraint system needing to be reset. It probably shut off the fuel pump to prevent fire.
Old Dec 28, 2019 | 10:50 PM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
After the car has sat for awhile do you hear the fuel pump prime when you open the driver door?
had same issue on a Chevy truck. Swapped relay with an inconsequential one in the fuse box and she lit off
Old Dec 29, 2019 | 07:56 AM
Flame Red's Avatar
Flame Red
I think I recall reading somewhere that if the air bags go off, the fuel pump is disabled to prevent any potential engine fires. I am going to guess it takes the GM Scan Tool to reset the air bag system - and a new air bag too?
To Fuel cutoff switch?
