Gremlins?!
Old Jan 10, 2020 | 03:07 PM
JMII's Avatar
JMII
Originally Posted by Maxpowers
and the main battery causes so many problems with the C7.
My guess is the composite body combined with all the vehicles electronics / computers is the reason for this. A small voltage drop could cause any number of systems to misbehave. All unibody steel vehicles use common ground, so the entire chassis offers a very low resistance return current flow. Not so with the Corvette where you have multiple grounding points, many of which are shared by various cable runs, all chained together that have different resistance levels. I've learned this by having a fiberglass boat where most electrical problems are simple grounding issues. Boat will not start? Wiggle the ground wire. GPS / Fishfinder turns off randomly? Wiggle the ground wire. This why everyone here tells you to disconnect the negative battery cable when any of the car's electronics act funny... its the old fashion wiggle the wire fix
Old Jan 10, 2020 | 03:41 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Kinda like "Alt Ctrl Del" when you get the BSOD!
Elmer
Old Jan 10, 2020 | 04:38 PM
owc6's Avatar
owc6
Originally Posted by Akcajunz
This is why I love the forum! I've read the owners manual cover to cover, and its probably in there, but I dont remember reading this little tidbit of information... Thanks c54U!!!
Don't feel bad, this tidbit is not in the OM.
Only here.
Old Jan 10, 2020 | 04:48 PM
SonnyAK's Avatar
SonnyAK
Just for peace of mind I usually swap my FOB batteries every 2 years even though they're not failing yet. Glad you had an easy fix!
Old Jan 10, 2020 | 05:04 PM
eboggs_jkvl
Moderator emeritus
From my Owner's manual for my 2014.
Keys, Doors, and Windows 2-7
If the transmitter battery is weak or if
there is interference with the signal,
the DIC may display a NO REMOTE
DETECTED or NO REMOTE KEY
WAS DETECTED. PLACE KEY IN
TRANSMITTER POCKET, THEN
START YOUR VEHICLE. message
when you try to start the vehicle.
See Key and Lock Messages on
page 5-35.
1. Place the transmitter in the
steering column transmitter
pocket with the chrome buttons
facing up and the base towards
the passenger side.
2. With the vehicle in P (Park),
N (Neutral) or, Neutral, press the
brake pedal and the ENGINE
START/STOP button.
Replace the transmitter battery
as soon as possible.
Old Jan 10, 2020 | 05:22 PM
CP's Avatar
CP
Paragraphs are your friend.
Old Jan 10, 2020 | 05:36 PM
2016C7.paul's Avatar
2016C7.paul
Old Jan 10, 2020 | 06:05 PM
eboggs_jkvl
Moderator emeritus
Copy and paste from the Owner's manual is my friend too. Read it, ask less questions.
Elmer
