Remote Start not working sometimes?
Old Jan 30, 2020 | 03:19 PM
acnburner194's Avatar
acnburner194
Default Remote Start not working sometimes?
Anyone know why the remote start doesn't work sometimes? I would hit the lock button on the key fob and hold down the button to perform the remote start but sometimes it doesn't start the car. Anyone know why? It seems that the key fob itself is working because I can lock and unlock the car just fine, but sometimes the remote start doesn't work. I keep the key fob in my room at home so the fob itself isn't cold. I did notice that the remote start function doesn't work as much when it's colder outside so could the weather be the issue? I also noticed that sometimes when the remote start doesn't work and manually start my car, the "check engine light" is on and turns off when the car is started. Is that another issue I should be worried about or is that normal? Thanks!
Old Jan 30, 2020 | 03:28 PM
glava2876's Avatar
glava2876
Any Check Engine light prevents the remote start from working -did you check to see if you have any codes?
Old Jan 30, 2020 | 03:52 PM
geraldschumann's Avatar
geraldschumann
On my 2016 base Stingray 1LT A8, I only get two remote starts before I have to do a regular one while sitting inside the car.
Old Jan 30, 2020 | 03:57 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When the car starts, all of the dash lights come on to show you they are functional. Then when the car starts, they go off and will come back on to indicate a problem. If the SES light does NOT stay lit, you are not throwing a code.
Even though the doors are opening with the FOB, a cheap test might be to replace the batteries in the FOBs and see if the problem persists.
Elmer
Old Jan 30, 2020 | 04:04 PM
lifter213's Avatar
lifter213
Does it work ok trying to start it from your phone or watch on the app? That might help you confirm if its a key fob issue or not.
Old Jan 30, 2020 | 09:13 PM
Kvou812's Avatar
Kvou812
It will also not work if the other remote is left in the car.
Old Jan 31, 2020 | 09:31 AM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
If attempting multiple "Auto-Starts", after the second Auto-Start with your FOB, you must preform a normal start with the push button on the dash.
Old Jan 31, 2020 | 11:18 AM
c54u's Avatar
c54u
From the manual.....
The remote start will not operate if any of the following occur:
. The ignition is in any mode other than OFF.
. The transmitter is in the vehicle.
. The hood is not closed.
. The hazard warning flashers are on.
. There is an emission control system malfunction.
. The engine coolant temperature is too high.
. The oil pressure is low.
. Two remote vehicle starts have already been used.
. The vehicle is not in P (Park).
Old Jan 31, 2020 | 12:44 PM
acnburner194
Thanks for all the input! Really appreciate your guys' help. I did not know that you can only perform two remote starts in a row until you have to manually do one. I usually do try to start my car everytime via remote start so I think that may be the issue. I will test it out and update the forum.
Old Jan 31, 2020 | 03:59 PM
Mad*Max's Avatar
Mad*Max
this is the problem
Old Jan 31, 2020 | 04:46 PM
lazerdude's Avatar
lazerdude
This literally just happened to me. The remote would unlock the door as usual but the remote start began to not work. 2 weeks later the battery was dead in the FOB. Got out the spare and no issues.
Old Jan 31, 2020 | 05:36 PM
owc6's Avatar
owc6
It also won't start if the fob was close enough to cause the triple honk when you exited the last time, or if their was any theft attempt (inclination/intrusion alarm).
Old Feb 4, 2020 | 05:24 PM
markeaux's Avatar
markeaux
My 19 also intermittently does not remote start using fob or app. My 15 Yukon Denali did same. None of the issues detailed in the manual applied. Since it only happens about 10% of the time I haven't pursued investigating it. I did notice at least once it remote started with the app after it would not start with the fob. New fob battery has not helped.
Old Feb 4, 2020 | 05:41 PM
Akcajunz's Avatar
Akcajunz
See Post #7
Old Feb 4, 2020 | 07:23 PM
Mad*Max's Avatar
Mad*Max
I've had 3 GM cars with remote start and they work flawlessly and from over 300 feet away! I use the fob to perform the remote start.
Old Feb 21, 2022 | 07:45 AM
Avlvette's Avatar
Avlvette
1st Gear
Default Spare key
Make sure spare key isn't in the car
Old Feb 21, 2022 | 12:37 PM
orca1946's Avatar
orca1946
My cell phone in same pocket as FOB has caused problems.
Old Feb 21, 2022 | 02:33 PM
owc6's Avatar
owc6
You're pretty talented if you can go through the sequence to remote start while the remote is in your pocket. 😉
To Remote Start not working sometimes?
