DIY: Front view camera
Old Feb 25, 2020 | 07:08 PM
15Z06/07's Avatar
15Z06/07
Default DIY: Front view camera
Going to install a front curb view camera on my 2015 using a micro add a fuse. Any advice which fuse is best to double up on so camera power is shut off with ignition? Or any that you could use the on/ off switch for that accessory to power the camera on/off? Sorry if this has been asked before.... I’m new to forum. Thanks for any help!
Old Feb 25, 2020 | 07:25 PM
CP's Avatar
CP
www.navtool.com
Much easier with two people working on this.
Old Feb 26, 2020 | 12:39 PM
Bob Beroza's Avatar
Bob Beroza
Used the Fuse Tap to the Ignition Even Fuse. This insures that the camera is only on when the car is running.
Cut a small slit in the fuse using a Dremel to prevent the wire from getting pinched.
Hope this helps you!
Old Feb 26, 2020 | 12:57 PM
15Z06/07's Avatar
15Z06/07
Bob, does the car have to be running to give power or just in the “on” position? Also is this fuse #27? Thanks!
Old Feb 27, 2020 | 10:37 AM
Bob Beroza's Avatar
Bob Beroza
I have had the cam in there for 3 years and I don't think I ever realized if it does or doesn't need to be running. Also I'll don't remember the fuse number, but I'll check later today and get back to you.
UPDATE: I just checked and the car must be running for the cam to work.
Several of us on the forum worked out a simple inexpensive method for installing a front cam on early C7s and 1LT C7s. The thread ran on for a long time.
There complete instructions and a what products to order.
Below is the thread.
https://www.corvetteforum.com/forums...nt-camera.html
To DIY: Front view camera
