Bent wheels?
Old Feb 28, 2020 | 01:30 PM
Christopher Bookman's Avatar
Christopher Bookman
Default Bent wheels?
When I went to have my tires rotated recently at Discount Tire, the tech informed me that apparently 3 out of 4 of my wheels are bent. The bends are subtle, so you can't see them or feel them - it was only noticeable to him on the balancing machine. He said it would cost like $175 per wheel to have them repaired. I'm wondering, is this something I should do? I don't feel vibrations when I ride, but I'm worried about this voiding my tires' warranty.
Old Feb 28, 2020 | 05:03 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Do a search for bent wheels. 100's of posts
Old Feb 28, 2020 | 05:35 PM
keegs54's Avatar
keegs54
grand sport or zo6
Old Feb 28, 2020 | 05:41 PM
Christopher Bookman
Originally Posted by keegs54
grand sport or zo6
z51
Old Feb 28, 2020 | 05:42 PM
Avanti's Avatar
Avanti
"Do a search for bent wheels. 100's of posts." Yeah, on any given day there will be some here on the first page of this section's threads.
Old Feb 28, 2020 | 05:45 PM
vader86's Avatar
vader86
if you bought the wheel warranty, time to file. Otherwise its time to buy forged wheels.
Old Feb 28, 2020 | 06:03 PM
Zjoe6's Avatar
Zjoe6
Moderator
Originally Posted by christopher bookman
z51
zr1
Old Feb 28, 2020 | 06:05 PM
Christopher Bookman
Originally Posted by Zjoe6
zr1
huh?
Old Feb 28, 2020 | 07:43 PM
Scudz's Avatar
Scudz
I went to BBB arbitration, won my case, and got paid $4940 from GM for my aftermarket replacement wheels.
Old Feb 28, 2020 | 07:47 PM
Christopher Bookman
How did you do that?
Old Feb 28, 2020 | 07:55 PM
Scudz's Avatar
Scudz
https://www.corvetteforum.com/forums...-warranty.html
https://www.corvetteforum.com/forums...roll-call.html
Old Feb 29, 2020 | 08:33 AM
Zjoe6's Avatar
Zjoe6
Moderator
huh?
Meaning they've all had bent wheels reported here. Z51,Grand Sport, Z06, ZR1.
Old Feb 29, 2020 | 11:34 AM
Red86Cfour's Avatar
Red86Cfour
Wide body cars are the majority of bent wheel claims. Base and Z51 wheels are much less prone to bending or failure. They do happen, though a lot less frequently.
Old Feb 29, 2020 | 11:52 AM
slburgie's Avatar
slburgie
my 19 GS has a small rhythmic vibration that comes and goes in 1-2 second intervals. ALL tires were road forced to 10lbs or less, two had been 30lb plus and replaced. Could the vibration be coming from bent wheels or out of balance tires. I always believed constant vibration were tires in most cases. Harmonic rhythmic types of vibrations could be slightly bent wheels. I've got 2400 miles on it and its possible I could have bent one on these roads with some pretty sharp edged pot holes although I try and watch for them carefully. Any similar?
Old Feb 29, 2020 | 01:14 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
I had the same vibration from my right rear AS3+. Had the tire replaced under warranty, which significantly reduced the vibration (no more 1-2 sec harmonic; still trying to decide whether *all* of the vibes are gone, as I only have ~20 miles on it so far, with only a few at ~60 mph). If I conclude there is still some residual vibration, II'll have the wheel checked for bends at the place I've used in the past for wheel repairs.
To Bent wheels?
