Battery volts
Old Mar 1, 2020 | 04:45 PM
Neil Baker's Avatar
Neil Baker
Default Battery volts
What is the normal battery volts for C7 Z51 with M7? Mine goes from 12.5 to as high as 15. Usually 13.0 to 14.0
why the big difference?
Old Mar 1, 2020 | 04:46 PM
ersatz928's Avatar
ersatz928
Normal.
Old Mar 1, 2020 | 05:09 PM
jimmbbo's Avatar
jimmbbo
After starting the voltage should stabilize between 13 and 14.5 volts... consistent readings above 15 likely indicate a problem, often a battery going south.
Old Mar 1, 2020 | 07:12 PM
Dcasole's Avatar
Dcasole
Normal , the ECM controls the Alternator now and only supplies what the car and battery need ....
Dave
Old Mar 1, 2020 | 07:42 PM
badhabit_wb's Avatar
badhabit_wb
I agree it's normal. I bet in cold weather it goes above 15v. Mine does.
To Battery volts
