Hub-centric wheel
Old Mar 28, 2020 | 07:59 PM
ILXgirl's Avatar
ILXgirl
Default Hub-centric wheel
What does that mean on an aftermarket wheel.
Old Mar 28, 2020 | 08:04 PM
FX VETTE's Avatar
FX VETTE
Default Courtesy of Discount Tire
Hub-centric wheels are designed for the hub center bore of the wheel to be a perfect match to the vehicle. This allows the wheel to be centered on the vehicle hub, which is the most accurate way to center the wheel. Most original equipment wheels are designed to be hub-centric because the manufacturer designs wheels specifically for each vehicle.
Old Mar 28, 2020 | 08:26 PM
Cman01's Avatar
Cman01
Basically what the above poster said.
https://www.tsw.com/explore-tsw-cust...ric-wheels.php
Old Mar 28, 2020 | 08:33 PM
ILXgirl's Avatar
ILXgirl
Thanks for the useful info.
Old Mar 28, 2020 | 10:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
There have been some discussions about this in the past, and the consensus was that Corvette wheels are lug-centric; where the coned lug nuts position the wheel as the nuts are tightened.
Old Mar 28, 2020 | 10:45 PM
FX VETTE's Avatar
FX VETTE
What consensus was that? A few CF members replying? Then why would Cray Wheels say this - We have a deep and abiding knowledge of the nuances of Corvette engineering, so that precise wheel offsets, rear cavities sized to accommodate oversized Corvette brakes and aggressive suspension components, hub-centric center bores that hug your Corvette without centering rings, and many similar requirements, are just second nature to us. ?
https://www.craycorvettewheels.com/e...technology.php
Old Mar 29, 2020 | 11:11 AM
Maxpowers's Avatar
Maxpowers
The Crays on my C7 are definitely hub centric. No adapter required.
Old Mar 29, 2020 | 12:10 PM
Gearhead Jim
St. Jude Donor '13
I presume that Cray could make hub-centric wheels for Corvettes, but that's not the way our factory wheels are done.
Here's the discussion from the C6 section, C6 wheels mount the same as C7 wheels.
https://www.corvetteforum.com/forums...ubcentric.html
Post #28 is the official answer from Chevrolet:
Hello,
I see a lot of back and forth on this question. Just want to clear things up. They are not hub centric. The wheels are centered on the stud and are lug centric.
A hub centric wheel is centered upon installation by the machine fit over the hub, hence the term, the OEM wheels on the ‘Vette are lug-centric, meaning that they are centered by the lugs making it critical that a proper torque sequence, on jack stands, is followed. Not properly following the torque procedure will result in an off center wheel and a vibration concern. Hope this helps.
Geoff Allen
Chevrolet Customer Service
Old Mar 29, 2020 | 01:22 PM
Maxpowers's Avatar
Maxpowers
Perhaps my understnding of hub centric is off. My OEM and Cray wheels fit tight to the hub such that the lugs and threads align without any wiggle room.
I agree the strength comes from tightening the lugs to support the weight (and keep the wheels from flying off).
To Hub-centric wheel
