Corvette shutters
Old Jul 9, 2020 | 09:06 PM
japour's Avatar
japour
5th Gear
Default Corvette shutters
I have a 2016 Corvette that shutters . The service bulliten says to replace the transmission fluid. I have a full warranty. They want me to pay $800 because the say fluids are not covered.
If the fluid is the cause , it should be covered. Does anyone else have the same issue?
Old Jul 9, 2020 | 09:16 PM
Dif's Avatar
Dif
Others should chime in, but you need to find another Dealer, no way should you have to pay
Old Jul 9, 2020 | 09:24 PM
Vet Interested's Avatar
Vet Interested
Also who is the dealer trying to screw you over? Don’t be afraid to mention their name.
Old Jul 9, 2020 | 09:31 PM
mdiiulio's Avatar
mdiiulio
Time for a new dealer. Post your location, or even better, post up in your respective regional forum, and you're likely to find dealer recommendations from the forum as well.
/forums/upcoming-events-and-regional-discussion
Old Jul 9, 2020 | 10:21 PM
Elk's Avatar
Elk
See, the attached
File Type: pdf
Old Jul 10, 2020 | 08:49 AM
japour's Avatar
japour
5th Gear
Default shuttering
The dealer is Depaula Chevy in Albany NY ,,,,,8000 miles on the car, GM problem and I have to pay. I am going to call a competiter to see that they charge.
Old Jul 10, 2020 | 08:54 AM
yellow2007's Avatar
yellow2007
DO NOT PAY!!!!!!!!!!!!!!!!!!!!!!!!!
My 2015 got TWO triple flushes no charge.....the dealer even gave me a loaner both times.
Old Jul 10, 2020 | 09:06 AM
Elk - thanks for posting that TSB.
Old Jul 10, 2020 | 09:16 AM
slant6's Avatar
slant6
got mine done a year ago, and didn't even have the shutter no questions asked
Old Jul 10, 2020 | 09:19 AM
bjones7131's Avatar
bjones7131
I took TSB to my dealer and they did the fluid change with no questions asked and gave me a loaner. I wasn't having any issues but tsb said if customer complains change the fluid no testing or driving the car and this is what I pointed out when I took my car in and they said OK. Shifts a lot smoother and as everyone that has on says, GET A RANGE DEVICE AND B DONE WITH IT.
Old Jul 10, 2020 | 10:37 AM
japour's Avatar
japour
5th Gear
I called GM and they are looking into it......they will not release car until I pay.
Old Jul 10, 2020 | 01:11 PM
bartsky's Avatar
bartsky
Absolute BS!! I would be livid myself!
Old Jul 10, 2020 | 01:52 PM
ljorges's Avatar
ljorges
Does that TSB cover cars that are out of warranty? Do out of warranty cars have to pay?
Just picked up a 2015 Z06/Z07 with 3900 miles. No shudder but this worries me.
Les
Old Jul 10, 2020 | 01:57 PM
Elk's Avatar
Elk
It is not a recall so I assume those with cars outside of warranty need to pay.
Old Jul 10, 2020 | 02:32 PM
Rebel Yell's Avatar
Rebel Yell
That's what you should do japur. Depaula is just trying to screw you over. They'll charge you, and then turn it into GM as warranty work for a second payment I'm sure. If I were you, when you get this taken care of I would put this out on Google reviews, and www.dealerrater.com. Let all know what this dealer is about. Good luck.
Old Jul 10, 2020 | 03:58 PM
Dif's Avatar
Dif
Les
From all the posts about this subject, it all depends on the Dealer, warranty or not.
Some members have posted no problem, no questions asked when getting the new Fluid installed even when not under warranty.
Some,.. when not under warranty mention it was $600.00 for labor, and again, it all depended on which Dealer they went to
Bottom line, when still under warranty, it's free/suppose to be free, but as with said Dealer mentioned, they're trying to make more money.
Old Jul 10, 2020 | 06:46 PM
Tommy79's Avatar
Tommy79
Default Me 2
Just had the triple flush done last week (6/2020.) No questions asked.
NOW... my 2019 is under warranty... That may be the issue here.
To Corvette shutters
Old Jul 12, 2020 | 07:34 PM
japour's Avatar
japour
5th Gear
The final decision is after a call to GM and they contacted Depaula Chevy of Albany , Depaula picked up the tab.......it sucks that you have to argue until the sun comes out.
Old Jul 12, 2020 | 08:32 PM
khearon23's Avatar
khearon23
Gonna see how my local dealer treats this when I approach them this week. I drive with my Range connected at all times since I purchased, but I move it from the Vette to the Avalanche and I've forgotten it once or twice.
Old Jul 13, 2020 | 07:14 AM
japour's Avatar
japour
5th Gear
I would be interested in knowing if you had to argue like i had to.....
