Question On Removable Top
Old Jul 30, 2020 | 09:01 AM
2ndvett01's Avatar
2ndvett01
Default Question On Removable Top
2019 1lt Stingray coupe: I’ve read a post that using rubber o rings on the front “pins” stops top rattling. On my top there are conical rubber grommets. Will o rings be of any use to stop rattling?
Old Jul 30, 2020 | 09:05 AM
Zjoe6's Avatar
Zjoe6
I thought I read that someone put shrink tube on the pins but that was about a million posts ago. It's a little foggy. I know there are cheap mods you can do that work.
Old Jul 30, 2020 | 09:15 AM
ICU2TV's Avatar
ICU2TV
People have done this in my group and it has worked well. My C7 does not make noise but the C6 does and nothing seemed to work.
Old Jul 30, 2020 | 09:21 AM
Z51C7's Avatar
Z51C7
The O-Ring is a common fix.
I never had to use the rings but had issues with the rubber seals being dry. I used the Gummi Pflege applicator on all the rubber seals and
that helped me out.
Amazon Amazon
Good luck!
Old Jul 30, 2020 | 11:29 AM
Grand Slam's Avatar
Grand Slam
O-rings worked for me. They have to be large enough not to slip down through the hole at the base of the conical receiver.
Old Jul 30, 2020 | 11:38 AM
4thC4at60's Avatar
4thC4at60
There's a latch fix... I did it to my C6 early on and drove it another 128,000 rattle free miles
Old Jul 30, 2020 | 12:21 PM
No noise from my top yet, but will keep the o-ring fix in mind should I need it.
Old Jul 30, 2020 | 01:58 PM
Avanti's Avatar
Avanti
To be more specific... sometimes one full-turn of the rear latch, tighter, will help, too.
Old Jul 30, 2020 | 04:16 PM
jimmbbo's Avatar
jimmbbo
My '19 had some nasty squeaks/rattles which sounded like they were all over the interior.
I removed the top, cleaned all the contacting rubber surfaces then applied three coats of
303 weatherstrip protectant 303 weatherstrip protectant
, allowing it to dry in between coats. I also tightened the aft latch a turn and it's been silent since...
Old Jul 30, 2020 | 07:08 PM
Elvira15's Avatar
Elvira15
With your ride being so new, seems you’d be able to get a fix from the dealer. I had mine “repaired” back in 2015.
Happy driving!
Old Jul 30, 2020 | 11:32 PM
blackmagic9805's Avatar
blackmagic9805
I have had good success using clear color dielectric grease on the seals, front latch rollers, grommets, and even rear pins.
Old Jul 31, 2020 | 04:37 AM
Grand Slam's Avatar
Grand Slam
Can the rear latch be turned without un-tightening a retaining screw? There looks like one at the base of the latch.
Old Jul 31, 2020 | 04:38 PM
2ndvett01's Avatar
2ndvett01
If you have the rubber grommets on the front posts do you still need rubber o rings to stop the rattling?
Old Jul 31, 2020 | 05:12 PM
Red86Cfour's Avatar
Red86Cfour
Two very small dabs of bearing grease in the right places on the locking lever pads does wonders....
Old Aug 2, 2020 | 10:00 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The set screw is usually tight enough that you can't turn the "hook" to adjust tension, without loosening the screw. It's a small metric Allen wrench.
You can adjust the rear latch without removing the top, but be careful not to loosen the screw any more than necessary- it can fall out and disappear forever.
If your are going to experiment with adjustments, the hook will stay put enough to do some testing without tightening the screw until you decide what tension to use.
My experience 2001/2006/2009/2017- slightly loose is better than a bit too tight. Keep track of which way you are turning it (1 turn either way is usually the limit) so you can go back to original.
Also, I use Dielectric Silicone Grease on the rubber, but DSG is squeaksville on the latches. Super Lube paste works well on the latches for me.
To Question On Removable Top
