Tire Pressure
Old Aug 9, 2020 | 09:27 PM
Adir Hassid's Avatar
Adir Hassid
Default Tire Pressure
Hey guys, just a heads up.
Make sure your tire pressure isn't too high. I got my C7 GS a month ago and I felt like it was excessively ancy, even in tour mode.
The other day I looked at the doorsill sticker and it is said that your cold tire PSI should be 30PSI, I was at 34 PSI cold. I got myself a little meter and adjusted the cold PSI to get to 30.
What a world of a difference. The car feels so much better, pretty crazy how such a little adjustment can have such a bing outcome.
Old Aug 9, 2020 | 09:33 PM
I have always kept the tires on my Corvettes at 30 psi cold - have not encountered a problem at that pressure level.
Old Aug 9, 2020 | 09:34 PM
mjcourt's Avatar
mjcourt
Always good to keep track of tire pressure. About 6 months ago I test drove a brand new Miata. The ride was very rough, even the mirror was shaking on the windshield. I questioned the sales guy and he said everything gets verified when a car come in. I grabbed the pressure meter out of my car and checked and the meter pegged at over 50 psi!
Old Aug 10, 2020 | 07:03 PM
JMII's Avatar
JMII
Yikes! That is crazy high goes to show what their idea of "verified" means. My guess is the car got washed and vacuumed then thrown on the lot. They likely didn't check a thing because tire pressure would be like #2 or 3 after brakes and wheel nuts as far as safety goes.
Old Aug 10, 2020 | 07:30 PM
Blu-Beast's Avatar
Blu-Beast
same here
Old Aug 10, 2020 | 07:47 PM
gpotski's Avatar
gpotski
Big tires are very temperature sensitive.
Old Aug 10, 2020 | 08:16 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
There was a year or two where the sticker said 35 psi for some C7's, but that was just a cheap trick by GM to get very slightly higher MPG in the testing.
As others say, you want 30 psi cold. 35 cold will degrade the ride, handling, and tire life.
Old Aug 10, 2020 | 10:33 PM
Avanti's Avatar
Avanti
Some years ago I experienced the same situation with another new sports car. Worthless d**ned dealer prep... and, it's not all GM by any means.
Old Aug 10, 2020 | 11:09 PM
madrob2020's Avatar
madrob2020
Not just “low level” techs at dealers. MANY times I’ve had tires put on & they just look at MAX pressure on sidewall & fill to that. Never understand why people don’t at least try to do due diligence of checking things after any work. Just a simple visual of under the hood can save misery. 😎
Old Aug 11, 2020 | 02:01 AM
Skid Row Joe's Avatar
Skid Row Joe
I always check tire pressures at start up in the ICD. It's identical to using my air pressure guage.
Old Aug 11, 2020 | 08:12 AM
Zjoe6's Avatar
Zjoe6
Always 30 cold. I keep an eye on them when I'm driving.
Old Aug 11, 2020 | 04:02 PM
Ultimate ride's Avatar
Ultimate ride
When I bought my new to me 2016 C7 and drove it home from the dealership it felt like it had no suspension. When I checked the tire pressure I found someone had put 48 psi in each of the 4 tires! I didn't notice the hard ride when I tested the car as I was in heavy traffic the for entire test.
Old Aug 11, 2020 | 04:03 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Yep, that usually my choice on the instrument panel I do what I got to do pushing buttons, but leave it there when driving..
Old Aug 11, 2020 | 10:11 PM
jimmbbo's Avatar
jimmbbo
I use 27 psi cold... gives a bit of a smoother ride without any noticeable tread wear problems...
Old Aug 11, 2020 | 11:22 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I was wondering about lower than 30psi. I live in Las Vegas, and it sure gets hot here in the summer. With the tire pressure set at 30psi cold, after driving in this heat, the pressure can go up to 35psi. I have a GS, and know about the wide body wheel problems. I was thinking about setting the cold pressure at 28psi, so it will go up to about 32 or 33psi while driving. What do you people think?
Old Aug 12, 2020 | 02:55 AM
Skid Row Joe
Me too! I figure it's pretty important info in real time!
Old Aug 12, 2020 | 08:13 AM
bjones7131's Avatar
bjones7131
I leave mine at 28 cold, rides softer and no noticeable difference in tire ware going on 3.5 yrs. 9.5K miles. Should be easier on the cracked wheel issue as well.
To Tire Pressure
Old Aug 12, 2020 | 08:26 AM
madrob2020's Avatar
madrob2020
Originally Posted by bjones7131
****** Should be easier on the cracked wheel issue as well.
With these low profile & next to no rubber between road & wheel, less air in tire means less stiff rubber to absorb some of the shock going over expansion joints, potholes, etc. Rubber with less air pressure will allow tire to flex more which COULD lead to sidewall cracking also. JMO
Old Aug 12, 2020 | 08:36 AM
Red08's Avatar
Red08
Originally Posted by Blu-Beast
same here
Ditto
Old Aug 12, 2020 | 09:23 AM
Jerrys-1LT's Avatar
Jerrys-1LT
I live in Vegas also and was wondering the same thing. I'm sure you've noticed that our excessive summer heat makes tires hard as rocks after around 5 years. So I wonder if it would be a bad idea to run lower pressure for fear of sidewall cracking.
I just replaced tires on my 2015 Honda (only had 17000 miles on them) and the difference in ride is remarkable. I knew they were getting hard by the lack of traction. I don't know how old your tires are but I think the stiffness once they harden will be the real danger to your wheels.
