Battery Tender problem
Old Aug 14, 2020 | 11:28 AM
Halloweenvette's Avatar
Halloweenvette
Default Battery Tender problem
I purchased a new Battery Tender Power Tender Plus High Efficiency 12V5A with a 12V power plug to insert into the charger port in the trunk of my Vette..
The charger would only blink the yellow light after being hooked up and never change. The manual says that is due to an incorrect hook up.
I contacted Delran, the manufacturer of the charger. They told me the charger has to be directly connected to the battery.
I haven't tried this yet.This doesn't seem logical.
Has anyone had a similar problem?
Old Aug 14, 2020 | 11:36 AM
mschuyler's Avatar
mschuyler
Try pushing the plug into the socket in a more firm manner. The connection is a little flaky and requires a solid push. Just happened to me last week. I noticed the yellow light, shoved the plug in, and it all started working again.
Old Aug 14, 2020 | 11:58 AM
Globeman's Avatar
Globeman
Originally Posted by mschuyler
Try pushing the plug into the socket in a more form manner. The connection is a little flaky and requires a solid push. Just happened to me last week. I noticed the yellow light, shoved the plug in, and it all started working again.
What he said.
If that doesn't do it, there’s a fuse in the Battery Tender 12V plug. Check that. Then try connecting directly to the battery. If that works, look for a blown fuse in the circuit going to the car’s charging port.
Old Aug 14, 2020 | 01:40 PM
Jayhawk94's Avatar
Jayhawk94
As Globeman said, check the fuse in the 12V adapter. The black tip of the adapter, where the metal spring loaded tip is, just unscrews and there is a 3A fuse inside. The problem is that the battery tender is 5A. I had the same problem, replaced the fuse and went back to using it with my 1.25 Amp tender. Moved the 5A tender to one of my other cars so I could connect directly to the battery.
Old Aug 14, 2020 | 03:05 PM
Skid Row Joe's Avatar
Skid Row Joe
Yup.....somethin' ain't making contact.
Old Aug 14, 2020 | 04:27 PM
iclick's Avatar
iclick
Originally Posted by junior1017
I contacted Delran, the manufacturer of the charger. They told me the charger has to be directly connected to the battery. I haven't tried this yet.This doesn't seem logical. Has anyone had a similar problem?
No, and it isn't necessary. If their claim is true why do they sell a lighter adapter? I used my very old Deltran BT+ with the lighter adapter on my first C7 for two years and never had a problem. My current GS came with the Ctek maintainer and I've been using it now for >3 years. It had a problem early on with connectivity and I sent it to Ctek for warranty service, whence they replaced the male connector. That worked fine for a while but I still have sporadic connectivity issues which is always rectified by Mschuyler's suggestion to just push on it a bit harder.
Old Aug 17, 2020 | 06:29 PM
Halloweenvette
I did what the tech at Deltran suggested. Connected the charger cables directly to the battery.
Works fine.
Go figure?
Old Aug 17, 2020 | 08:28 PM
Avanti's Avatar
Avanti
"Connected the charger cables directly to the battery. Works fine." If you do as suggested here it should still work at the rear-plug.
(btw, I used the things for years and it didn't matter where I connected them)
Old Aug 18, 2020 | 03:39 PM
ETHYL's Avatar
ETHYL
Same problem. make sure its fully into the trunk connector i
Old Aug 29, 2020 | 12:46 PM
Halloweenvette
Lost all memory functions after connecting direct to battery. Had to reprogram everything.
Old Aug 29, 2020 | 01:59 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Very strange! I connect mine in the socket when I come back from a trip without a problem. I would also check the fuze.
Old Sep 4, 2020 | 12:15 PM
sgt1372's Avatar
sgt1372
This is not true.
I've hooked up a Battery Tender (I've got 6 of them; one's a dual mode for my F250) to my MB ML350 via the hot jumper post in the engine compartment and just grounded it to a bolt and it works fine.
However, I just bought my C7 and few days ago and have already installed a quick disconnect pigtail on the battery in the trunk and it chraged up fine and is in the green as we speak. So, a direct connect can be easily installed in your C7.
Old Sep 4, 2020 | 05:15 PM
Bill Dearborn's Avatar
Bill Dearborn
Works fine.
Go figure?
So what did you do? Cut off the power plug so you could add clips to fasten to the battery terminals? The plug in the cargo compartment is connected directly to the battery. The wires go directly from the plug to the battery. With the low level current used to maintain the battery the small wires going from the plug receptacle to the battery don't cause a problem applying a charging force to the battery.
Bill
Old Sep 4, 2020 | 05:51 PM
sgt1372's Avatar
sgt1372
Bill
The Battery Tender comes w/2 different connectors. One w/clips and the other w/a modular quick disconnector. No cutting necessary.
Old Sep 4, 2020 | 07:52 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I would return the charger and get one that works properly. It makes no sense that it doesn’t work on the rear hatch, unless the plug s not working. The whole idea of changing through the rear hatch plug is for the convenience of the car owner.
But that’s me!
Old Sep 5, 2020 | 08:28 AM
rrsperry's Avatar
rrsperry
Stupid question but did you check that the plug in the trunk works? If the fuse to that is blown, it would behave just like what you experienced.
Old Sep 5, 2020 | 03:10 PM
johnny3's Avatar
johnny3
I have to twist the connector after I push it in its socket & watch the lights til they stop blinking, that indicates a good solid connection of both + & -.
To Battery Tender problem
Old Sep 8, 2020 | 08:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The socket in the trunk of our 2017 is also pretty chintzy. Dealer replaced the GM charger once under warranty because it kept losing connection in the socket, but the problem is really in the car and not the charger.
Old Sep 9, 2020 | 12:21 PM
MiamiCowboy's Avatar
MiamiCowboy
I connected one ring lead to the positive post on the fuse box under the hood and grounded the other lead. I routed the cable out the front grill. Allowed enough lead to store behind the grill when driving the car. When I pull into the garage I fish out the wire and plug into the tender. Battery charges just fine and I am not connected directly to the battery. Did the same to my C5 and C6 Z06 Corvettes. Never had to open the trunk and the battery is always charged.
Old Sep 10, 2020 | 10:15 PM
iclick's Avatar
iclick
That's a good solution and is similar to the method I used on my C6, which was easy since the battery on that car was in the engine compartment. There was a small slot in the LF wheel-well liner and I tucked the connector in that slot when not connected. It was almost as if that slot was designed for that purpose.
But for the C7 just popping the trunk lid and inserting the connector was too easy to pass up. As I stated earlier I used my old Deltran BT+ with the lighter adapter for my first C7 and never had a problem, but the Ctek that came with my current GS occasionally loses its connection. This doesn't happen often enough for me to go to another procedure, however, and works well enough. My garage is secured and I just open the hatch lid, insert the connector, and lower the lid without fully closing it after every drive. In 15 min. or so the system goes to sleep and the security system will not enable while the lid is ajar.
I rigged my truck up the way you did, running the cable to the grill, and the old BT+ still has a mission after 15 years. It's been used on three Harleys, a C2, C6, and one C7. My ZTR mower is connected to a 5w Deltran BT Solar, as it's housed where there is no AC power.
