Starting problems
Old Sep 7, 2020 | 06:33 PM
CP's Avatar
CP
Default Starting problems
Had the OEM battery replaced less than a year ago and last week the car has been exhibiting problems starting. On Sunday, it totally wouldn't start and had to have it jumped. Got the car home and put a charger on it and disconnected the battery from the car. Hooked everything up and car started fine this morning. A couple hours later tried starting and had difficulty. Got the tender on it now so it will start tomorrow.
I'm guessing a bad battery, but the holiday doesn't help getting this resolved.
Old Sep 7, 2020 | 06:37 PM
TxLefty's Avatar
TxLefty
I believe you're right. Should get a full replacement. Sometimes you get a bad one. Funny how they seem to know when to die.
Old Sep 7, 2020 | 06:58 PM
Roastum1's Avatar
Roastum1
I bet you do have a bad battery. My job we install alot of batteries. Some only seem to last a couple years anymore. I changed mine out this summer the original was from 2014. Purchased a agm installed it hit the starter and click click click. Only had 9volts the company said that was 1st one they had seen bad. Needless to say I changed it twice.
Old Sep 7, 2020 | 11:57 PM
Obe1 GS's Avatar
Obe1 GS
I would verify that there's good connections between the cables and the battery; a loose connection could cause the same issue.
Old Sep 8, 2020 | 07:28 AM
4thC4at60's Avatar
4thC4at60
Laughing. You get six years out of the OEM battery and then install a different brand....
Old Sep 8, 2020 | 04:28 PM
Roastum1's Avatar
Roastum1
For sure
To Starting problems
