8 speed auto. trans.
Yesterday I took my 2016 corvette to my dealer because of either the transmission of torque converter has a problem. Two of my club members had their torque converter or transmission changed.I have 18,400 miles and I started feeling shudders and jerking. I was told to take it in. My 3 year warranty is over but wanted to know if there was a recall due to a defective trans.
I was told that they would flush the fluid and reprogram the trans. does this sound like a fix??? $1,500,00.
Go on Goggle , Look up GM TSB 18-NA 355 . Mobil One has a new fluid to fix this .LV ATF HP Blue lable .GM will pay for this . 1,500.00 is you getting ripped off . Good Luck , Power train warranty is 4 years . Get a Range device .
The following 2 users liked this post by dfkruger:
Corgidog1 (09-17-2020),
Rebel Yell (09-17-2020)
Received 19,589 Likes
'20-'21-'22-'23-'24
$1500 - sounds like they are trying to screw you. Get a second opinion and mention the power train warranty coverage.
TSB: 18-NA-355 addresses the shudder and explains the triple flush. TSB: 16-NA-014 addresses the torque converter flood back. If you are not experiencing a delayed and harsh engagement when putting the car in drive after sitting overnight, focus on the flush.
Although mine was still under warranty, I thought GM had a bulletin and covered the cost of yours to do the flush & fluid change.
I’d question them harder, or check w a different dealer.
Isn’t your drivetrain warranty still valid?
Received 5,273 Likes
Just another helpful GM dealer... NOT!
Get your facts/data together and go elsewhere. You should be fine.
yellow2007 (09-17-2020)
Received 3,148 Likes
Finalist 2020 C7 of the Year -- Unmodified
I just use the paddles 100% of the time. Good luck with your fix!
I don't get the "use paddles all the time" your still using your tranny and t. converter not bypassing then????
Received 2,639 Likes
The flush, and refill with new fluid helped my previous '16 a lot. And yes, at $1500 dollars they should at least kiss you first.
Kevin A Jones (09-17-2020)
