lug nuts
Old Nov 16, 2020 | 02:57 AM
firstvette99's Avatar
firstvette99
Default lug nuts
is the size a 3/4 socket to remove?
thanks
Old Nov 16, 2020 | 05:21 AM
Lug nut size is 19mm on the C7.
Old Nov 16, 2020 | 09:57 AM
shakinrock's Avatar
shakinrock
some will say you can use 3/4 but don't, use only 19mm
Old Nov 16, 2020 | 10:07 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I would also say use a 19mm Socket with nylon protector on it as well... better safe than sorry.. no hydraulics either.. no need to chew things up.
Old Nov 16, 2020 | 05:55 PM
Avanti's Avatar
Avanti
A good quality socket the correct size with name-brand lug-nuts, hand torqued, and you don't need bother with nylon protectors.
Old Nov 17, 2020 | 11:47 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
A 19 mm socket is .748"; a 3/4" socket is .750; the difference is .002", hardly enough to be concerned about.
Old Nov 18, 2020 | 11:00 AM
weathermaker's Avatar
weathermaker
.002” is about the thickness of a human hair!
Old Nov 18, 2020 | 12:28 PM
BostonVette's Avatar
BostonVette
Well then...let's not split hairs!
BTW - what size wrench removes the oil drain plugs, nothing i have fits snug on those plugs; English or Metric
I just bought 2 new ones because i know they will round eventually
Old Nov 18, 2020 | 12:53 PM
Elk's Avatar
Elk
15mm
To lug nuts
