Recurring CEL
Old Dec 23, 2020 | 06:30 AM
Srkegler's Avatar
Srkegler
Default Recurring CEL
Not really a problem but just bugs me. Every couple of weeks A CEL pops up. Print out shows bank 1 O2 sensor lean to rich. Make appointment for repair, and light goes out after couple days. Have been told bad gas, have been told driving habits, have been told low fuel. Only use top tier fuel, never go below 1/4 tank. Anyone else have this problem. I have an 18 convertible with 48k on the clock.
Old Dec 23, 2020 | 06:46 AM
99vetteran's Avatar
99vetteran
Do you have any mods like headers, cat delete?
Old Dec 23, 2020 | 08:11 AM
Srkegler's Avatar
Srkegler
Nope, completely stock. Clears itself after couple days, waits a week a comes back on
Old Dec 23, 2020 | 08:35 AM
JMII's Avatar
JMII
Maybe the sensor itself is bad
Old Dec 23, 2020 | 08:51 AM
Tommy79's Avatar
Tommy79
Next time the CEL comes up, drive to the dealership and let them see it. They probably will not be able to fix it, but they can at least scan it to see what the issue is.
Old Dec 23, 2020 | 10:23 AM
99vetteran's Avatar
99vetteran
I agree with Tommy but even if it turns off by the time you get there it should still show the history of it coming on and hopefully it will give them a clue to why its coming on.
Old Dec 23, 2020 | 10:53 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
^^^^ This.
The light might go off but there is a history code in the ECM. Sounds like you have a bad O2 sensor. Sounds like the dealer is guessing and doesn't want to put in a new sensor.
Elmer
Old Dec 23, 2020 | 10:57 AM
Jeff V.'s Avatar
Jeff V.
I'd also guess the sensor is on the verge of failure. Or possibly a chafed wire to that sensor. How much gas you have in the tank has zero bearing on the car's air/fuel ratio. Even if it did, it would affect both banks.
Old Dec 24, 2020 | 05:02 PM
Avanti's Avatar
Avanti
Wonky sensor, wire, and/or connector are most likely culprits. One would think it would be saved in history, but I've seen times nothing was... for whatever reason and the dealer had to actually see the CEL in person. One reason it may be good to have ones own cheapo code-reader, to possibly (though not guaranteed) to get a better indication of what's really going on. All the best.
Old Dec 24, 2020 | 05:07 PM
Bill Dearborn's Avatar
Bill Dearborn
I agree with the others about the history code telling the mechanic where to look. However, did you take it to the dealer after the CEL turned off or did you cancel the appointment?
Bill
Old Dec 24, 2020 | 08:06 PM
PatternDayTrader's Avatar
PatternDayTrader
Schit o2 sensor.
Bank on it.
Old Dec 26, 2020 | 07:35 PM
Srkegler's Avatar
Srkegler
I've taken it to the dealer 3 times, light was on when they did the scan, always came back left bank 02 sensor lean to rich. Dealer made an appointment for me each time but light was off by appointment time. Was given a different excuse each time, bad gas, driving habit, low fuel, etc. I'll just put up with it until it completely fails. Thanks for thbe reply's.
Old Dec 26, 2020 | 07:59 PM
PatternDayTrader
Just throw an o2 sensor at it. You can thank me later.
Old Dec 27, 2020 | 07:58 AM
weathermaker's Avatar
weathermaker
Our ‘19 GS did the same thing. Dealer replaced o2 sensor. Took a week to get one but all is well.
To Recurring CEL
