My First Launch Control Run
Old Dec 26, 2020 | 11:39 AM
mattya9's Avatar
mattya9
Default My First Launch Control Run
To start I have a stock 2019 A8 Z06. I have to admit I was a little nervous because I'm still new to the car and getting used to her. With that being said holy S%&T!!! I now personally know what the feeling is like after reading you guys rave about it on here! However, I'm wondering if my tires might be a little too low on their tread (4/32) or if the road I was on wasn't in the best shape for launching? The reason I say this is because as soon as I let off the brake the *** end kicked out to the left a fair amount while the wheels spun a bit. Then as I was starting to zoom down the road the car just felt unsteady and like I was going to lose control at any moment. As soon as I hit 60 I immediately came off the gas and started braking. Needless to say my adrenaline was going pretty good at that point but underneath that was this uneasy feeling that the car was right at that envelope edge. Is this just me not being used to the launch control experience? Or could it be something physically related to the car or road I was on? I realize unless you were there it's almost impossible to tell but just trying to get a little more info before I try it again.
Matt
Old Dec 26, 2020 | 12:22 PM
Elk's Avatar
Elk
Using launch control is driving the car at close to the edge of the envelope. Things can go bad fast, especially with a Z06.
The warmer and stickier the surface and your tires the better the launch will be.
Old Dec 26, 2020 | 02:45 PM
dvilin's Avatar
dvilin
As you stated without being there hard to offer a precise response. A lot does depend on road service and tire temperature, weather, etc.The rear end kicking loose a bit is normal, along with some wheel spin. Once launched and over the wheel spin however the car should feel stable and pull strongly like a train as they say. I have been well up in the triple digits in my Z and it felt stable. Mine being a M7 there is a bit of looseness up to 3rd gear where you definitely are feeling you are on the edge.
Old Dec 26, 2020 | 02:55 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
I watched a few videos of this before I did it . There was one by an older guy in Fla. in his white z06. He did about 3-4 runs and I did not see his breaking loose any time .
Old Dec 26, 2020 | 03:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Different pavement? Different temperature? Different tires or tread remaining?
Old Dec 26, 2020 | 06:31 PM
1FINE99's Avatar
1FINE99
Cruise-In V Veteran
Exactly !
Old Dec 26, 2020 | 07:45 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Be sure your front wheels are straight. Being a little off can have that effect.
Old Dec 26, 2020 | 11:28 PM
mattya9's Avatar
mattya9
Watched the same video and figured my attempt would be just like it. Was definitely not based on what I watched and what I felt haha.
Matt
Old Dec 26, 2020 | 11:30 PM
mattya9's Avatar
mattya9
As I look back I think the pavement could’ve been a littler better and the tires could have a lot more tread/be newer.
Matt
Old Dec 27, 2020 | 08:26 AM
449er's Avatar
449er
CF Community Team
This is how many Corvettes end up in the nearest ditch when the car feels "on the edge". Utube is full of these exploits
Old Dec 27, 2020 | 08:52 AM
Dcasole's Avatar
Dcasole
Launch control cannot overcome conditions, as mentioned above it depends on a lot of things .... . I personally use it a lot at the track with my Bolt ON LT1 , the car would be faster launching without it but I prefer the consistency it provides me when using the factory runflats , I leave on the last yellow and I can't count the number of the many much higher horsepower cars I left sitting on the line smoking their tires trying to play catchup as i was already 60 ft down the track .....
In the summer time when it's warm it's like getting shot out of a cannon , when the temps drop you can feel the ECM pulling power as the tires fight to maintain their grip .
Dave
Old Dec 27, 2020 | 11:33 AM
PJO's Avatar
PJO
Veteran: Marine Corps
Also the crowning on most road surfaces vary. Depending on that crown can have a great impact on how any car reacts during hard acceleration.
Old Dec 27, 2020 | 11:52 AM
Dcasole's Avatar
Dcasole
Crowning on the road is where the Driver Mod has to kick in and just correct for it .....
Dave
Old Dec 27, 2020 | 12:13 PM
Buttersvette's Avatar
Buttersvette
Agree... through 3rd gear this car scares the crap out of me. Have not given full throttle yet because it wants to go side ways getting on freeway!! Need to be in wide open area to test full throttle and see what it does.... with no ditches or trees near by!!
Old Dec 27, 2020 | 12:29 PM
Dcasole's Avatar
Dcasole
No matter what, you really have to be one with the car and respect that amount of HP it produces as a ZO6 is a 10 second street car right off the showroom floor on the factory RUN CRAPS and with not much work and a set of drag radials it can dip into the high 9 second range .
Not to long ago a car that did 13 seconds in the 1/4 mile was considered crazy fast and to get it any faster required a lot of money and skill
There are not to many people that can drive a 10 second car that has street tires on it ... and these are the guys you see getting in trouble, Some of the same guys that have enough money to buy a 1,000 HP ocean racer .......
It is going to feel loose and it is going to spin the tires into 3rd gear if you let it , the object is to give it as much power as the tires can handle and keep it under control for the conditions
Dave
Old Dec 27, 2020 | 12:42 PM
Elk's Avatar
Elk
Originally Posted by Dcasole
No matter what, you really have to be one with the car . . .
This covers it in a nutshell.
Traction control and stability control are mere aids, but you remain the driver.
My suspicion is there are many more crashes of high horsepower cars now involving misuse of power than there were before the nannies. Before the nannies you knew you had to take responsibility and listen to the car or you would instantly be spit off the road.
Too many drivers now put their foot to the floor and expect the nannies to not only give them the best performance but save them from disaster. This is not how it works.
Old Dec 27, 2020 | 12:53 PM
Dcasole's Avatar
Dcasole
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ THIS ^^^^^^^^^^^^^^^^^^
No truer words are spoken ....
To My First Launch Control Run
Old Dec 27, 2020 | 03:09 PM
HOXXOH's Avatar
HOXXOH
I highly recommend practicing launches in large and empty parking lots, until you can run the first 100' in a straight line. Then hit the dragstrip (1/8th mi) to get higher speed experience. Public roads are never the same, so you don't know what works and what doesn't. When you learn the basics in a controlled environment, you'll have a better chance of correcting problems in the wild vs experiencing bad results.
Old Dec 27, 2020 | 10:39 PM
The LT1 can get away from you if you are not careful - I can only imagine how easy it is for the LT4 to do the same.
Old Dec 28, 2020 | 10:34 AM
mattya9's Avatar
mattya9
I've definitely experienced this where I've given it a little too much gas and the *** end comes out a little bit. That was with the nannies on and thus they did their job. But to your point, had I kept on the throttle the *** end would have definitely come out full circle! Because of this power I'm very hesitant to try another launch any time soon.
Matt
