General Maintance
Old Jan 4, 2021 | 11:35 AM
ajc7's Avatar
ajc7
Navigator
Default General Maintance
What would be a good type of maintance practice to get in to with my C7 LT 1 other then the normal changing of oil..
Old Jan 4, 2021 | 11:37 AM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
* Maintenance
Follow the schedule in the owner's manual.
Old Jan 4, 2021 | 11:38 AM
ajc7's Avatar
ajc7
Navigator
Hmmm don't know why I didn't think of that one ....thanks !
Maxpowers's Avatar
Maxpowers
Follow the sched in the owners manual. Change oil when OLM says to.
Old Jan 4, 2021 | 11:53 AM
slant6's Avatar
slant6
would change rear Diff, my 2017 was 1/2 quart and my 2019 Zo6 was full quart low
Old Jan 4, 2021 | 07:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The car should give good service by just following the manual. If you want to be conservative, do the scheduled maintenance at 3/4 of the miles recommended instead of going the full distance.
I do a sort of hybrid conservative- make sure I never exceed the manual miles/time, and often do the work somewhat early just because of scheduling issues.
Old Jan 4, 2021 | 08:23 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Hey bud is your car a dry sump or wet, and manual or auto trans?
I like to do an oil change at 500 miles (especially if it's a wet sump), then pretty much follow the manual.
I also do a diff fluid change at 1,500 miles and a transmission fluid change (manual car) sometime around 10k.
Old Jan 4, 2021 | 08:28 PM
Avanti's Avatar
Avanti
Simply as stated... that's why there's an Owner's Manual. If you don't have one replacements are available.
Old Jan 4, 2021 | 09:26 PM
Originally Posted by 919cw313
* Maintenance
Can't get much better than that.
Old Jan 5, 2021 | 10:37 AM
ajc7's Avatar
ajc7
Navigator
Thanks for all the great information. Being a driver, not a mechanic especially on this sophisticated of a vehicle I will take it to my local Chevy dealer for all maintance. I think in the long run it would be the safest way I, sure not the cheapest but.......
Old Jan 5, 2021 | 11:24 AM
Maxpowers's Avatar
Maxpowers
Not sure where you live, but be sure to go to a good dealer that works on vettes. Check out the regional forums for recommendations.
Old Jan 5, 2021 | 11:32 AM
JMII's Avatar
JMII
Good point as many have reported the diff being low from the factory.
Also if this is a new car its not a bad idea to do a "break in" change of many of the fluids like tranny and diff within the first 1,000 or so miles. While not specifically mentioned the serve schedule normally applies to lots of short trips so I tend to follow that schedule to be on the safe side. Thankfully the C7 has a OLM so it will tell you when to change the oil by calculating time, temperature and other factors besides just miles.
Just don't let them sell you on additional BS service items like injector cleaners, if it's not in the manual then you likely don't need it. However with that said you might want to put some Techron Fuel System Cleaner in every now and then to keep your fuel sending unit from getting stuck as past Corvette owners indicate this can happen. Finally if you have manual transmission the clutch fluid tends to get dirty and thus requires more frequent replacement then the manual suggests.
Old Jan 5, 2021 | 06:10 PM
ajc7's Avatar
ajc7
Navigator
Yes I totally agree with you about the the serve advisor trying to sell additional items not needed. And thanks for the tip on the Techron Fuel System Cleaner !
Old Jan 6, 2021 | 10:52 PM
Skid Row Joe's Avatar
Skid Row Joe
Follow the schedule in the owner's manual. Unless you're operating in severe conditions...
Old Jan 7, 2021 | 07:00 AM
BigJay08's Avatar
BigJay08
I cant remember if this is in the manual, but be sure to remember to flush your brake fluid. My buddy had old fluid in his C6 z06 and it pulsed on him and faded bad at heavy breaking until he flushed his system with new fluid.
Old Jan 7, 2021 | 10:35 AM
ErnieN85's Avatar
ErnieN85
Yes every two years is a good idea, unless you track it or use Castorl SRF
Old Jan 7, 2021 | 11:49 AM
blackandgold's Avatar
blackandgold
If you've got an M7 the ranger method of changing the clutch fluid is super easy and keeps the fluid fairly clean inbetween full flushes.
To General Maintance
Old Jan 7, 2021 | 02:09 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I only drive about 3500 miles a year, but I still change the oil once a year.
Some say to change the rear-diff fluid after a year or two(when purchased new). ?????
Call me crazy but I spray my fan belts once a year with WD40 so they don't dry out. I'm pay for sharing this
Old Jan 7, 2021 | 02:49 PM
JMII's Avatar
JMII
Per GM you have to change the C7's oil once a year regardless of mileage.
Old Jan 8, 2021 | 09:48 AM
CraigStu's Avatar
CraigStu
Yep, I am still not satisfied w/ these oil change monitor systems built into the car. If you wait for that light to come on the oil is really ugly looking. I am not real thrilled w/ that tiny filter on my base 19 Stingray either. I got my car used in Dec 19 w/ 3800 miles on it. Soon I noticed some off brand filter so did a change at 4500 miles but used 5-30 Mobil 1 and a GM filter. Car now has 11k on it and I have never seen a light yet. I changed to the 0-40 Dexos2 and GM filter last week. I have no idea if the dealer had reset the oil system when they changed the oil but I know I didn't. So it went from at least 3800 to 11000+ w/o a light. Not my idea of a proper oil change interval. Maybe I am too old fashioned.
