backfire
Old Jan 21, 2021 | 03:48 PM
94c4george's Avatar
94c4george
6th Gear
Default backfire
Test drove C7 Grand Sport 2019 yesterday that backfired thru when I heavy accelerated from a stop.
Is this normal ?? Car only had 6,200 miles on it. Thinking of upgrading from our C6.
Old Jan 21, 2021 | 03:54 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Those are Bald Eagles screaming from the exhaust...perfectly normal.
Old Jan 21, 2021 | 03:59 PM
C7&7's Avatar
C7&7
Backfired or just starting popping when you were on it hard and then let off the gas? The exhaust popping on decel is very normal. If the car truly backfired that is not, however I think you're just hearing the exhaust screaming
Old Jan 21, 2021 | 05:26 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
OP;
If it is for sure "back-firing" under load, then there is an issue with the tuning of the engine.
Normally, it is unburnt fuel hitting the exhaust and igniting usually exaggerated by lean conditions due to the higher exhaust temps. If you have the NPP (GS models do) exhaust in quiet mode you will rarely hear it, but it's quite pronounced with the NPP exhaust in the open position.
I would strongly suggest up-dating and up-grading to the newest possible C7 Corvette, you and your family can afford.
"You will not be disappointed".
Many thanks,
Ray
Old Jan 21, 2021 | 07:28 PM
Dcasole's Avatar
Dcasole
Are u talking about the POP on the shift , that s normal as the ECM cuts the ignition for a mili second on the shift which results in the POP you heard
I did the same thing on my test drive , scared the hell out of me as I thought something broke lol
Dave
Old Jan 21, 2021 | 07:41 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Backfiring under heavy acceleration is not normal.
Exhaust popping, when backing off from higher RPM, is completely normal.
Old Jan 21, 2021 | 09:37 PM
orrwhat's Avatar
orrwhat
Also if you are not use to active exhaust, it may have been the exhaust valve starting to open.
Old Jan 21, 2021 | 10:05 PM
Ask the dealer to check the car over due to your concern. If not from a Chevy dealer, ask if they will take it to a local Chevy dealer for evaluation.
Old Jan 22, 2021 | 07:39 AM
shakinrock's Avatar
shakinrock
I would test drive the car again, under hard acceleration. First in sport mode, then in touring mode, then in eco mode.
[I welcome a correction here] If you hear the same loud noise (that you thought was a backfire) then there is a problem, otherwise not.
Old Jan 22, 2021 | 10:53 AM
Dcasole's Avatar
Dcasole
The OP needs to define when this noise happens and how often ... as there is not enough info here
If uts a pop during hard acceleration right at the shift from 1st to 2nd and if going fast enough 2nd into 3rd ... then it's normal
Old Jan 22, 2021 | 02:46 PM
lakemg's Avatar
lakemg
100 % Agree! Spot on normal for the A8 with NPP (I can't speak for the manual or A6 cars with NPP)...those that say this is not normal (with A8/NPP) must have never really pushed hard on the throttle - LOL
Old Jan 22, 2021 | 05:36 PM
owc6's Avatar
owc6
A6 also barks at WOT.
It's a glorious sound.
Old Jan 22, 2021 | 07:08 PM
lakemg's Avatar
lakemg
Old Jan 23, 2021 | 08:53 PM
94c4george's Avatar
94c4george
6th Gear
Thanks for all the input. We went back and purchased a certified pre-owned 6300 mile, 2019 Grand Sport 3LT.
Now I need to check the info about which tires are quite !
Old Jan 23, 2021 | 11:21 PM
owc6's Avatar
owc6
Well, during the summer, the OE PSS are quite sticky; during the winter, not quite so much.
much.
Old Jan 24, 2021 | 01:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Tire noise depends a lot on what kind of pavement you're driving on, and of course on speed.
Newer tires are quieter than older used tires of the same model, so comparisons are difficult.
Most people here say the AS3+ ZP are quieter than the PSS ZP that come on the car, and a bit smoother.
We bought AS3+ ZP and a second set of wheels just after buying the car itself, swap out every Spring & Fall, so I have done back to back comparisons when each set of tires was almost new, and at about 10k/20k/30k miles. Most of the time, I can't tell any difference between them in ride or noise. Except that the AS3+ don't throw small stones at the bottom of the car like the PSS do.
Old Jan 24, 2021 | 04:10 PM
c5arlen's Avatar
c5arlen
I'd say the exhaust note popping and cracking is the goofy firing order of Chevy... We used to call em thumpers back in the day.... Thump thump thump and pop pop.
Old Jan 24, 2021 | 04:17 PM
owc6's Avatar
owc6
The bark is, as was said upthread, a micro second of fuel cutoff to facilitate faster gear change.
Old Jan 25, 2021 | 04:33 PM
NukeMMC's Avatar
NukeMMC
Different brands/models have different noise characteristics. Toyo R888 Proxes are wonderfully sticky and provide all the traction your GS will need, but are quite loud in comparison to other patterns. My Notto NT05s were decent for noise and great tractions. Currently have Michelin PSSs that are OK for both and had Eagle F1 G2 that were decent for noise but traction was wanting.
To backfire
