Auto heat setting maybe not working
when I set my temp to say 72 degrees it just blows out at a high speed. It never lowers down the fan speed. It blows out from the defogger. I just bought this 2016 1LT stingray. Am I doing something wrong? I thought it would maintain the temperature and adjust accordingly.
It regulates the fan speed, air flow dash or floor, defog, Recirculate on/off, AC on/off.
But, when the Auto Mode light is on, you can hit the buttons to regulate where you want the air flow, dash only, floor only, or both, and Recirculate on/off.
Yes, when you do that, the Auto light goes out.
But,.. the system is still in Auto Mode but now it only controls fan speed and AC on/off to maintain the Temperature setting.
The only time the system will go Completely out of Auto Mode is by changing fan Speed manually.
That puts the whole system in Manual Mode, and you have to make "all" changes manually to maintain your Temperature setting.
Case in point:
In Manual Mode with fans set to high, temperature 72, the system will not maintain the Temperature if the Cabin Temperature gets higher or lower because Manual settings do not change.
So you have to Manually keep making changes to stay in your comfort zone.
After I turn On the Auto button, I press the button/s to direct air flow, dash, floor, or both, and the rest only makes changes Automatically to fan speed and AC on/off to maintain my Temperature.
From then on, if I need it warmer or cooler I only change the Temperature setting and the system Automatically maintains it with fan speed and AC on/off, but my manual settings for air flow etc stay the same.
At least that's how my 2016 2LT works for me.
Hope this helps
It takes the place of an On/Off Button.
