E Dif control module failure
Old Feb 4, 2021 | 06:20 PM
leadville1's Avatar
leadville1
Default E Dif control module failure
I kept getting service rear axle warning and it turns out the control module failed. The reason it failed was because there were only two bolts in it, instead of four. The car had been in an accident on the opposite side of the car, so we assumed it was during the accident it was re-assembled and subsequently overlooked. But judging by where the repair was it seems more likely that either it was delayed failure or perhaps they even loosened from vibrations in the car? Has anybody else had this failure in their car? I would presume the bolts are locktited in place.
Old Feb 5, 2021 | 09:59 AM
ersatz928's Avatar
ersatz928
Are you talking about the 4 screws that attach the cover of the module? Or screws that attach the module to the car??
Old Feb 5, 2021 | 12:54 PM
leadville1's Avatar
leadville1
Bolts to the car, they came lose on mine. It was being held on by one nut.
To E Dif control module failure
