15” conversion
Old Feb 12, 2021 | 02:56 PM
aaaman99's Avatar
aaaman99
Default 15” conversion
I’m thinking about pulling the trigger on doing a 15” conversion. I’d like to see some that are already done! So post your setup and give details if you don’t mind.
Old Feb 12, 2021 | 03:57 PM
robert miller's Avatar
robert miller
Default ttt
Should be the same as for the c5 or the c6 set up per say. I will say this don't use the 15,s on the street due to that tall side wall if you get into a dip are low spot in the road it will make you azz end really go from side to side really fast. But I do love the look of that in the rear & even more those bead lock set up. Robert
Old Feb 13, 2021 | 11:14 PM
123sugey's Avatar
123sugey
Dig
The 15” conversion C7’s look bad azz for sure !! Quite a bit of $ for the look. Some believe they need it to hook but tires, alignment and a few other things can make that happen. I’m doing everything possible at this time to plant the rear tires and hook better. Lots of options before buying the 15” conversion.
To 15” conversion
