Carbon flash application
Old Feb 23, 2021 | 04:22 PM
rwilson3944's Avatar
rwilson3944
Default Carbon flash application
I have a set of ABS black spats that I would like to change to carbon flash. How difficult is it to use the carbon flash spray paint and then clear coat spray?
Old Feb 23, 2021 | 04:46 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
It is easy to do. I painted the mud flaps on mine. You would need a primer too. Do a search for painting a splitter. There are a few that take you through the steps of painting bare plastic.
Old Feb 23, 2021 | 05:42 PM
bbrown450's Avatar
bbrown450
Surface prep is key , , you have to sand them down to give the paint something to grip on , I would also recommend some plastic adhesion spray / primer.
Old Feb 24, 2021 | 10:46 AM
Maxpowers's Avatar
Maxpowers
Surface prep is key.
Old Feb 24, 2021 | 11:23 PM
Exactly. Do the prep right, the rest should turn out well.
To Carbon flash application
