Blew my diff using launch control
Old Feb 27, 2021 | 12:08 PM
Blackstingray6.2's Avatar
Blackstingray6.2
2nd Gear
Default Blew my diff using launch control
Last night I blew my differential using launch control. I have a MT stingray with stock power levels. I know the spider gears are weak links and that’s what I think failed. I wanted to know if there was much of a difference between the z06 and stingray e diff and if it would fit onto my car. If not any advice on how to repair this and make it stronger so this won’t happen in the future would be appreciated.
Old Feb 27, 2021 | 12:10 PM
Maxpowers's Avatar
Maxpowers
Do you still powertrain warranty? With stock power this rare.
Old Feb 27, 2021 | 12:14 PM
Blackstingray6.2
2nd Gear
Unfortunately I do not. My car is a 2015 Z51 with 28k miles
Old Feb 28, 2021 | 07:32 AM
ftlaud1's Avatar
ftlaud1
60 month 100k miles, did you just miss the 60mo?
Old Feb 28, 2021 | 08:44 AM
Dcasole's Avatar
Dcasole
So now to answer your real question as I am sure you know when your warranty was up .....
I am sure you have found out as many already have , axle hop is not your friend as it will instantly take out the spiders
There is a 4 spider gear conversion but you might be better off going with a wave track , just depends on your hp level, tires you are using and your goals , occasional drag strip ?
Do a search on ad there are many threads on this
Dave
https://www.corvetteforum.com/forums...-or-axles.html
Old Feb 28, 2021 | 08:45 AM
Dcasole's Avatar
Dcasole
No .... not rare at all ... with a stick car it's actually pretty easy to do
Dave
Old Feb 28, 2021 | 08:58 AM
stephen1254's Avatar
stephen1254
Wavetrac diff from RPM - you can have shorter gears installed at the same time.
Old Feb 28, 2021 | 10:49 AM
BlueDevilZ51's Avatar
BlueDevilZ51
Sure you didn’t just break an axle, that breaks more often using LC
Old Feb 28, 2021 | 11:45 AM
Maxpowers's Avatar
Maxpowers
Dave
Didnt realize that with stock LT1 power.
To Blew my diff using launch control
