Automatic Shift Knob Chipping
Old Apr 8, 2021 | 10:00 AM
PDQ's Avatar
PDQ
St. Jude Donor '07
Default Automatic Shift **** Chipping
My 2019 Grand Sport, Automatic Shift **** has developed Four small chips at the top edge. These are small "pin head" size that are now showing the bare metal below the plastic coating. I do not wear a ring on my right hand, therefore that is not the cause. Looks to me like possibly defective coating? Anyone else notice this situation? Would this be warranty, car will be 2years old in May.
Old Apr 8, 2021 | 10:08 AM
MikeBravo56's Avatar
MikeBravo56
St. Jude Donor '12-'13-'14
My 2019 rag top is doing something similar. Black coating has chipped off to the plastic underneath. About an eight of an inch around. I do not wear a ring on my right hand either.
LT4CMG's Avatar
LT4CMG
It’s a warranty issue. Take it in. As long as there are no clear scratch/gouge marks, indicating you damaged it, it’s 100% warranty. I’ve had that covered under warranty on my previous CTS
Old Apr 8, 2021 | 11:04 AM
PDQ's Avatar
PDQ
St. Jude Donor '07
Thank you for the response.
Old Apr 9, 2021 | 12:20 PM
I would say it should be covered under warranty. Take it to the dealer and see about getting it replaced.
Old Apr 9, 2021 | 12:28 PM
Kevin A Jones's Avatar
Kevin A Jones
I guess the good news is that if for some reason GM won't cover it under warranty a replacement isn't very expensive and doesn't appear to be too difficult to install.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAA AABCAQAAAC1HAwCAAAAC0lEQVR42mN8Vw8AAmEBb 87E6jIAAAAASUVORK5CYII=[/img]
Shift ****
23157552Shifter & components, auto trans, red stitching.
$133.45
$84.44
Old Apr 9, 2021 | 04:44 PM
PDQ's Avatar
PDQ
St. Jude Donor '07
Shift ****
$133.45
$84.44
Thank you, sir.
Old Apr 9, 2021 | 06:46 PM
Kevin A Jones
Originally Posted by PDQ
Thank you, sir.
You're welcome. Keep in mind that the part # above is for boot with red stitching. GM offer several colors.
Old Apr 9, 2021 | 07:02 PM
Dt86's Avatar
Dt86
Anyone have any photos of this? I’m just curious what it looks like?
Old Apr 9, 2021 | 07:23 PM
Kevin A Jones
Here's what the shift ****/boot assembly looks like installed if that's what you want to see:
Old Apr 9, 2021 | 09:52 PM
Dt86's Avatar
Dt86
Sorry for not clarifying, I was looking to see what the chipping looked like.
Drkhrse's Avatar
Drkhrse
I have a 2017 Grand Sport that I purchased last July and had 39,000 miles on it. The shift **** was exactly as you described. Since the car was out of bumper-to-bumper I ordered one and replaced it myself for less than $100. It has now been 9 months and the new one is doing the same thing. Wish there was a better fix than replacing it once a year.
Old Apr 9, 2021 | 10:06 PM
Dt86's Avatar
Dt86
Maybe if you buy a new one you can spray some clear coat on it or some other protective layer before installing it. Seems like they never addressed the quality of the materials and replacing it will be a repeat failure.
Old Nov 30, 2021 | 07:03 PM
PDQ's Avatar
PDQ
St. Jude Donor '07
Update, Local dealer advised no warranty for this, advised I had to hit it with something to chip it. Has anyone had this happen recently since my original post?
To Automatic Shift Knob Chipping
