C7 storage
Old Apr 8, 2021 | 10:44 AM
ETHYL's Avatar
ETHYL
Default C7 storage
I have to park my C7 in a gsrage for 2 to 3 weeks at a time. Cannot use a battery tender as no electric service available. What ideas on how to prevent the battery from being able to start car
Old Apr 8, 2021 | 11:38 AM
Maxpowers's Avatar
Maxpowers
If its not an old battery it will survive 3 weeks. If you want to play it safe, pull off the negative. You will have to reindex the windows but thats easy.
Old Apr 8, 2021 | 01:00 PM
Kevin A Jones's Avatar
Kevin A Jones
I agree, IF your battery isn't old and towards the end of it's life cycle (5-7 years old), you should be fine.
Old Apr 8, 2021 | 01:26 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You could bring the battery home and keep it charged there if your worried
Old Apr 8, 2021 | 01:28 PM
orca1946's Avatar
orca1946
3 weeks ok. to pull the battery is a pain I have read!
Old Apr 8, 2021 | 04:35 PM
Vette junkie's Avatar
Vette junkie
You've got that right!
Old Apr 8, 2021 | 05:01 PM
ETHYL's Avatar
ETHYL
Old Apr 8, 2021 | 05:42 PM
Maxpowers's Avatar
Maxpowers
The OEM Delco battery doesnt have a pull strap. A post strap can damage the battery.
Old Apr 8, 2021 | 10:38 PM
Popping the negative battery cable off would be a good solution. However, a battery in very good condition should allow for a restart in 2-3 weeks of storage time.
Old Apr 8, 2021 | 11:09 PM
eseibel67's Avatar
eseibel67
Yes remove negative cable can be done in 1 minute and car will start guaranteed. Or if you feel like reading lookup transport mode but its a lot less work to just disable at battery.
Old Apr 8, 2021 | 11:12 PM
Obe1 GS's Avatar
Obe1 GS
You can also purchase a quick disconnect setup for you negative battery connection,
Old Apr 9, 2021 | 09:49 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Get one of those small rechargeable jump packs, charge it up and leave it in the trunk of the 'vette. They will hold their charge a long time, but do recharge it occasionally.
If your batter actually dies, use the mechanical key to get into the trunk (may set off the alarm), pull the tap to release driver's door, use jump pack.
When they first came out, there were a few fires caused by faulty units but I haven't heard of anything recently.
If your car won't start after 2-3 weeks of storage, it probably needs a new battery anyway.
Old Apr 9, 2021 | 10:51 PM
Luzifer's Avatar
Luzifer
My car was in storage for close to 5 months for winter. The storage place will not put a tender on it, they disconnect the battery for all that time. I went to pick it up and the guy told me it started right back up. Once I got home I put the charger (15 amp) on it and 30 seconds later it said full charge. I don't know if they charged the battery the day before but it's fine.
Another thing they don't do, I had purchased tire saver ramps and they didn't want to put them either. Double set brand new in their carry bag. I had put extra pressure and the tires are fine.
Old Nov 19, 2023 | 07:31 AM
neilnoff's Avatar
neilnoff
I think the mystery has been solved. I installed a new 42 month AC/Delco battery and am back in business. Just to try and narrow down the possible problems, I plugged the CTEK into the trunk socket & wiggled it around to ensure a good connection, power light was on and red charging light was on. After 24 hours the lights were the same. What? 24 hours charging a brand new battery and the green "Charged" light did not come on? I have a brand new Battery Tender Plus that I then plugged into the trunk socket. When I checked back a little later, I had the green light saying it was charged. Wish I had a more logical brain and would have thought to try and isolate the problem earlier and saved some money in the process without having to buy a new battery. Oh well, the CTEK is in the trash and I'm going to use the Battery Tender Plus from Deltran next summer. Finger crossed! Thanks again to you all for the suggestions & comments -- good info and options that got me (finally) thinking.
Old Nov 19, 2023 | 10:28 AM
Bills17n72's Avatar
Bills17n72
To C7 storage
