Soler Throttle controller issue
Old Apr 10, 2021 | 12:15 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Default Soler Throttle controller issue
I followed the installation instructions to a tee. It threw a CEL and reduced power.
Disconnected the battery for 30 minutes and it still threw a CEL and reduced power.
Connected everything back to stock, disconnected the Soler and connected stock connector back to throttle, disconnected battery for 30 minutes and all is well.
Has that happened to anyone? Defective Soler ?
Popular Reply
Apr 18, 2021, 10:18 AM
corvettezman
Update:
Replacement came in yesterday. I installed it this morning and it worked like a charm. No issues with this one. Great service and quick response from Mike.
Set it to SP6 and it seems that's the setting me and the car are happy with. I know it does not add HP to the car but it sure feels like it.
Old Apr 10, 2021 | 12:48 PM
ImpliedConsent's Avatar
ImpliedConsent
Never heard of it throwing a CEL. Regardless: Soler Performance LLC, mike@solerengineering.com, www.solerengineering.com, (727) 667-9225 @Mike@SolerEngr
Old Apr 10, 2021 | 01:02 PM
corvettezman
Much appreciated!
I just called them . Very nice guy! A new one is on the way and a return label is in my inbox.
Thanks for the help.
Old Apr 10, 2021 | 01:03 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Mike probably can help but as previous post.. I have never heard of that code with a Soler
Old Apr 10, 2021 | 02:08 PM
Elk's Avatar
Elk
Mike's service is unsurpassed.
Old Apr 10, 2021 | 02:18 PM
92_383LT4's Avatar
92_383LT4
Old Apr 10, 2021 | 02:46 PM
jdp234's Avatar
jdp234
6th Gear
+1. I’ve got ~0 mechanical experience or aptitude and had a series of dumb questions on installing the TB/TC, Mike happily and helpfully talked me through them and I’ve been enjoying improved throttle response and smoother starts ever since. Great company!
Old Apr 10, 2021 | 09:40 PM
Avanti's Avatar
Avanti
Why not go directly to the source... Soler?
Old Apr 10, 2021 | 10:30 PM
Goat 2 Vette's Avatar
Goat 2 Vette
Originally Posted by corvettezman
Much appreciated!
He's a great guy! Mine works great and I was really disappointed that it wasn't as snappy as my brothers C6, and now it is.. Love it! There isn't a better mod, not even my supercharger..
Old Apr 11, 2021 | 12:07 AM
Even one of the best can have a problem - Mike will take care of you, as you have found out,
Old Apr 11, 2021 | 04:09 AM
jimmbbo's Avatar
jimmbbo
I had the TC intermittently go into limp mode and throw a P2138 throttle position sensor code. I disconnected the TC and contacted Mike. He had a replacement unit delivered with a return shipping sticker in a couple of days. The Replacement works as advertised...
IIRC he said the TC didn't recognize the lower end throttle position and went into limp mode.
As posted, Mike's the best when it comes to customer service.
Old Apr 11, 2021 | 04:33 AM
corvettezman
That's the code I was getting along with another, 2128 I believe.
He emailed me a RMA tag right away, I shipped it back within the hour and a new one is on the way.
Looking forward to having a good one installed.
Old Apr 11, 2021 | 12:41 PM
jimmbbo's Avatar
jimmbbo
Would that other vendors have the same focus on their customers. In too many cases when a problem arises, my blood pressure spikes at the thought of dealing with some CS agent in Bangladesh reading a scripted troubleshooting tree...
A bit of good news is having the knowledge of how the car behaves when it goes brain dead...
Old Apr 11, 2021 | 07:40 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
How are you getting rid of the code? Does it clear on it's own?
Old Apr 12, 2021 | 07:10 AM
corvettezman
Disconnecting the battery for 30 mins.
Old Apr 12, 2021 | 07:13 AM
corvettezman
If it's an old code. disconnecting the battery for that long will clear it. If it's a current code, it'll come back as soon as you start the car.
My handheld scanner was not clearing the code BTW. So had to go with the battery disconnect.
Old Apr 18, 2021 | 10:18 AM
corvettezman
Update:
To Soler Throttle controller issue
Old Apr 18, 2021 | 11:37 PM
jimmbbo's Avatar
jimmbbo
Update:
I recommended the Soler TC to a buddy of mine who has a '17 Z51... After he installed it he emailed me reporting he nearly color coded his underwear when he tried the Ludicrous mode...
Old Apr 22, 2021 | 09:32 PM
uvamack's Avatar
uvamack
Navigator
Mike totally stands behind his product. I had the exact same issue on my C7 and he sent one out overnight and then everything was good to go.
Old Apr 23, 2021 | 02:23 PM
baxsom's Avatar
baxsom
Has anyone had their car tuned with this installed. I had mine tuned this past weekend and during the tuning process the car went into reduced power mode and the screen on the soler went blank. I removed it and the car ran fine and we were able to finish the tune. Can they not be used if you change throttle sensitivity in the tune?
