Rear tow hook question
May 16, 2021 | 11:43 AM
What is located behind the threads on the rear tow hook. My hook has long threads and if it goes to far I was wondering what it would hit.
May 16, 2021 | 11:47 AM
St. Jude Donor '18 thru '25
It would hit the rear plastic before it hit anything way inside car I believe...
May 16, 2021 | 05:55 PM
Mine hook is longer, wont hit plastic. I can see something in the hole, not sure if its some kind of line or wiring.
May 17, 2021 | 04:39 AM
St. Jude Donor '13, '20-'21
Quote:
Originally Posted by
johnfin
I have the GM hooks and they are long. I had trouble getting the rear hook to go in. A little lubricant and it went in fine.
The hook did not get anywhere near the bumper. It was about three or four inches from the bumper.
May 18, 2021 | 09:45 PM
May 18, 2021 | 10:50 PM
What year is it? The first model year or two didn’t come with receptacles. But should be on the left side approximately in the middle between edge of diffuser and exhaust.
May 18, 2021 | 11:54 PM
The car in the pic you posted doesn't have the rear receiver.
If your tow hook is that long, put two jam nuts on it to limit depth if it doesn't have them already. You'll have to screw the hook in probably 4-6" before you hit anything.
May 19, 2021 | 10:33 AM
Piece
Is the threaded piece for the hook part of the frame or can it be removed/added?
May 19, 2021 | 10:58 AM
It can be added. ZL1 Addons used to sell it. Have no idea if they still do or if you can buy the factory piece individually.
May 19, 2021 | 12:50 PM
johnfin
I have one I could sell you.
May 20, 2021 | 12:44 PM
Rob Willis
How much shipped to 56073?
May 20, 2021 | 07:00 PM
Part
Does the threaded mounted receiver on the z06 and GS bolt to the bumper or is it a welded part of the bumper.
May 22, 2021 | 03:34 PM
