Soler Throttle Controller -- again!
Old May 18, 2021 | 07:35 PM
1000RR's Avatar
1000RR
I never stalled my M7 Z06, but did put the Soler TB and TC on and it just made the driveability that much better. If you like it how it is stock, I can't imagine you'd like it worse with the Soler on it... it's definitely an improvement. Is it a must have, nah. But it does drive so much better with it around 1st and very low rpms in 2nd. If stock suits your needs and likings, that's a bonus... as you save some money not listening to the mumbo-jumbo being discussed above
Old May 18, 2021 | 08:15 PM
rodsib's Avatar
rodsib
Originally Posted by Gixxerman
I am still not quite sure about OP statements. I understand you love the controller but are you bashing the Throttle Body? I see in your post you do not, or have not owned one? The throttle bodies real purpose on a car like my Z06 is to remove the supercharger lag/hesitation and give the gas pedal a more connected linear feel to it. I am not aware of the Soler TB's effect on the non-supercharged engines, as I have never driven one with it installed before or after. There are no modes or claims to any huge performance gains or drastic changes in modes .. it is a subtle change that changed my Z06 beyond my expectations. Having a connected smooth throttle with no hesitation is something I did not have on my Z06 before the TB. I may try the controller down the road, but smoother helps me drive faster in the corners in the long run.
I am in no way bashing the throttle body. In fact, I may opt for the throttle body myself. I saw a lot of posts where people installed both, the throttle body and the throttle controller, and I just wanted to be clear that the throttle controller is the only 'performance' mod I added in case someone was wondering what it was like to add that as a stand-alone.
Generally, I don't change the mechanics of the car because I have had some issues with previous cars that had been modified. My attitude is it's better to leave well-enough alone. Obviously, others change out just-about everything they can think of - and while that is not for me, I really love reading about what people have done to enhance the performance of the car and I am glad we have such a huge aftermarket that allows for people to play to their hearts content.
Old May 18, 2021 | 09:11 PM
astepup's Avatar
astepup
I put the Soler TC in my '19 A8 Stingray and it performed just as the Pedal Commander I put in my C6, being the throttle response was vastly improved. I'm usually at SP5 or 6, haven't tried the Ludicrous setting yet. For me it gives a much more "linear" feeling to the throttle so I don't have to push the foot feet thingy as far or as fast to get the response I want.
Old May 18, 2021 | 10:28 PM
Glock 23C's Avatar
Glock 23C
I installed my Soler TC about a month ago. I normally hang around the SP5 area. I have always played with the idea of moving to a Z06. However this little thingy has me re-evaluating the jump. The TC costs about 100 bucks and moving up to a Z would run probably 15 to 20g plus my vette. Is the Z worth the extra coin? Only you or I can answer that. Truly, with the M7 I have to be very careful going thru first to fourth.The tires break free real easy. For me the 100 bucks might have saved me thousands. The beast has been unleashed.
Very easy install, no codes, and great customer service from Mike.
Old May 18, 2021 | 10:43 PM
jimmbbo's Avatar
jimmbbo
Originally Posted by Cbr600F3!
Why are you guys stalling the engine to need such device. Sure, my 19 C7 has a slight hesitation off of first gear but that can be finessed by the trottle and clutch, nothing hard. Chevy has made a race car and everything is for a reason. Instead of changing the car, I change my technics. I also see no issues on 2nd to 7th gear up or downshift. Even the 1 to 4th gear skip
You are certainly entitled to your opinion and to use whatever technique suits your style, but an overwhelming number of Soler buyers have provided consistent feedback that the TB/TC provide a much more responsive throttle to bring the C7 to the performance level expected in $65k+ sports car... The fact that other manufacturers produced TBs/TCs before Soler was introduced indicates the issue has been around for some time, and if there were no market for the units, there would be no sales.
Dozens of CF posters have driven manual transmission cars for decades and attest to an aggravating, mushy, inconsistent C7 throttle response that is solved quickly and relatively inexpensively with the Soler units, yielding a car that is predictable and more fun to drive.
IMO the Soler TB makes the car's throttle respond the way it should have been from the factory, with the TC allowing adjustment of the response curve to the driver's choice depending on the situation.
Old May 19, 2021 | 05:50 AM
mdformula350's Avatar
mdformula350
update: first drive with all the mods and i was able to drive like i would think. just moving the gas if any and letting clutch out in the right spot yielded to me a more easily controlled go from a stop for my normal driving style.
very pleased.
i may play with the tc settings but currently at sp5 since most seem to like that.
Old May 19, 2021 | 09:54 AM
Elk's Avatar
Elk
Some cars exhibit more than a slight hesitation off idle, especially Z06s such as mine. Prior to replacing the stock throttle body with a Soler unit the care regularly stumbled off idle. Ridiculous. Yes, I can adjust but should not be forced to do so.
Regardless, there should not be any hesitation off idle. GM did a bad job.
Nonsense. GM intentionally programmed poor off idle behavior? Really?
As an aside, Corvette is a street car, not a race car.
Old May 19, 2021 | 10:23 AM
rodsib's Avatar
rodsib
"The beast has been unleashed" -- haha, yes, that pretty much sums it up!
Old May 20, 2021 | 12:57 PM
Ken_4fun's Avatar
Ken_4fun
SP6 is my setting I use.
Probably one of the best additions I have made to my 2017 Z51.
Ken
Old May 20, 2021 | 01:42 PM
TCRVETTES's Avatar
TCRVETTES
2024 C8 of the Year Finalist - Modified
I have been enjoying my Solar TC for 1 1/2 years now. When I got my 14 Stingray was disappointed that the throttle control was not accessible in the GM settings and still no change with my 19 GS M7. The TC was a great tool to bring the throttle to what GM sets it at for TRACK and beyond. The Customer Service at Solar Engineer is unbeatable. My TC stopped working and I disconnected it and reinstalled but could not get it to work.
I called Solar Engineering to ask if there were some other tests I could do since the 1-year warranty had expired. I was promptly told that the diagnostics that I did was what they would have suggested without their equipment, and then without me asking for it, they sent me a replacement at no charge. I took one minute for them to verify my address, two days later it arrived and has been installed. My right foot is happy again! This is a must have upgrade. Solar Engineering is the best
Old May 20, 2021 | 08:07 PM
jaiyenyen's Avatar
jaiyenyen
I was thinking the same but now that I have the soler tc I find my 2019 Grand sport a lot more responsive and fun to drive. I really can't see needing 650 hp as I can pretty much spin the tires in the first 3 or 4 gears fairly easily. At higher speeds the Z will continue to fly but where I live you lose your car and license for that kind of fun. I remember when I was young 300hp was a lot and I felt the 460 in my vet was kind of lacking, not anymore.
Old May 21, 2021 | 07:44 PM
94Green's Avatar
94Green
C6 of Year Finalist (stock) 2019
Well, I bought one and it arrived this afternoon. It's installed but where on earth do you hide the box that is part of the pedal plug in. I have no idea where to put that, it just can't lay on the floor under the pedal flopping around. Any help is appreciated.
Old May 21, 2021 | 08:37 PM
  #33
jaiyenyen's Avatar
jaiyenyen
When I installed mine I just left it on the floor to the right of the pedal, it does not move or get in the way of the gas pedal and you can't see it unless you crawl down there and look. Works fine for me that way.
Old May 21, 2021 | 08:38 PM
  #34
Elk's Avatar
Elk
I tucked it behind the carpeting directly behind the foot feed. It took a bit of effort.
Old May 21, 2021 | 11:28 PM
  #35
92_383LT4's Avatar
92_383LT4
Old May 22, 2021 | 11:01 AM
  #36
rodsib's Avatar
rodsib
I put a piece of velcro on the back and just stuck it to the carpet behind and to the right of the gas pedal.
Old May 22, 2021 | 11:47 AM
  #37
dwwalker14335's Avatar
dwwalker14335
I used HP Tuners to address this but the ability to select a setting looks to be very nice.
To Soler Throttle Controller -- again!
Old May 22, 2021 | 12:50 PM
  #38
Elk's Avatar
Elk
I considered this. It would have been a great deal easier and just as effective as tucking everything behind the carpet.
Old May 23, 2021 | 04:28 AM
  #39
94Green's Avatar
94Green
I got my Soler installed and got to drive yesterday quite a bit. I live in the city and have a manual transmission. Although fun, I find "OE" setting is probably still best because I don't want a speeding ticket. Still, the option is there when or if I want to adjust in the future, but I like the Original Equipment tuning the best.
Old May 23, 2021 | 08:47 AM
  #40
Elk's Avatar
Elk
The OE response curve provides for a tractable car. GM put time into it to make certain this is true. But it is a bit dull.
I suggest trying bumping the response up just a bit to make the throttle more sensitive. This may be a happy medium for you, still easy to drive but with the car more awake.
