Overheated
Old Jun 17, 2021 | 12:02 AM
msaldivar's Avatar
msaldivar
Default Overheated
I'm sure his has been posted countless times before...couldn't find it.
My 2014 C7 with 17,000 miles suddenly overheated while in a drive thru lane. I had just changed the oil and had only driven for less than a half hour.
I shut it off for a for a couple of minutes then proceeded when I could. I parked and let it cool for a few more minutes, then drove a short way home.
After parked for a few hours, I added a small amount of water to the reservoir then I went for a fairly long drive and all was fine. Water temp stayed at 220.
Any ideas what the overheat cause was? Stuck thermostat?
Old Jun 17, 2021 | 01:54 AM
Bill Dearborn's Avatar
Bill Dearborn
Some 14s have an issue with the fan controller. It shuts down in traffic and lets the car overheat. Usually turning the car off and back on resets the controller so it runs the fan. People resolve the problem by installing the 600 watt fan that came on the Z06.
Bill
Old Jun 17, 2021 | 09:55 AM
BigVette427's Avatar
BigVette427
Assume being a 2014 you have already changed the coolant at least once?
Old Jun 17, 2021 | 10:00 AM
That could be a good place to start looking.
Old Jun 17, 2021 | 10:13 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
More info needed.
Was the fan running on high or was it off and not making any noise?
https://www.corvetteforum.com/forums...-to-260-a.html
Elmer
Old Jun 17, 2021 | 10:50 AM
JMII's Avatar
JMII
In addition to the above mentioned fan issues the 2014 analog gauge is incorrect, use the digital gauge for the correct reading... should be about 20 degrees cooler.
To Overheated
