Remote top down function
Old Jul 31, 2021 | 04:25 PM
fyreline's Avatar
fyreline
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
Default Remote top down function
2014 Premiere Edition convertible. Just replaced the batteries in both my remotes. I decided to try all of the possible functions when I was done, and one remote works flawlessly while the other only lowers the top about a third of the way before it stops. Pressing "Unlock" again and then the "Lower top" button got it another third of the way, when it quit again. Once more on the "Unlock" button and then the "Lower top" button got it all the way down. Went through the whole cycle again, same results. One remote works fine, the top goes all the way down. The second remote takes three times to do the same thing. What think you, oh great Corvette gurus?
Old Jul 31, 2021 | 04:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Very interesting...
I'd swap the batteries between the FOBs and see if the trouble stays with the bad FOB or transfers to the current good FOB.
Then I'd make a conclusion.
Old Jul 31, 2021 | 07:50 PM
fyreline's Avatar
fyreline
Both brand new batteries, but I'll give that a try. At least I'm getting VERY good at opening the fobs to change batteries.
Old Jul 31, 2021 | 08:14 PM
yellow2007's Avatar
yellow2007
Brand new doesn't mean it's good. I had the exact same problem a month ago. Replaced batteries in both even though only 3 months old and no more top down issues.
Old Aug 2, 2021 | 02:13 AM
TyBoo's Avatar
TyBoo
My 2014 will do that too if I do not hold the button firmly enough. Firmly, as in a death grip on the remote. It also sometimes doesn't work unless I push the button just right, like with a bit of sideways pressure along with the death grip. Even changing hands or repositioning the fob in my hand might get it to work. I always chalked it up to poor connection of the contacts on the circuit board inside the fob. It has been that way since new.
Old Aug 2, 2021 | 08:30 AM
eboggs_jkvl
Moderator emeritus
Let me introduce you to a word, Smarttop.
Reasons for a Smarttop:
Smarttop has 2 modules that are installed on the car. One hooks up under the waterfall and the other unit plugs into the DTC.
Stock, you have to hold the top down button on the FOB during the entire top lowering process.
Stock, you cannot put the top up nor raise the windows with the FOB.
Stock, you have to depress and hold the dash button down during the entire down/up process.
Smarttop, you hold the unlock button for 3-4 seconds, the car beeps, you release the FOB button and the windows go down and the top goes down.
Smarttop, you press the lock button for 3-4 seconds, the car beeps, you release the FOB button and the top goes up and the windows go up.
Smarttop, you tap the bottom of the TOP button on the dash and the windows go down and the top goes down. You do NOT hold the button during the process.
Smarttop, you tap the top of the TOP button on the dash and the top goes up and the windows go up. You do NOT hold the button during the process.
There might be a time where you have the car parked with the top down and it starts to rain. I can put my top up from a very good distance without having to sprint to the car, get in and press and hold the top button to get the top up. Also, at 77 years of age, my "sprint" is not as sprinty as it used to be.
Smarttop also is a great way to save the FOB battery. Holding down the button to lower the top eats up the FOB battery.
Smarttop is a VERY good device to have on the convertible. Too bad GM didn't engineer this into the car as an optional setting.
One caveat! They do not have Smarttop perfected for the 2019 model as far as I know.
Elmer
Old Aug 2, 2021 | 01:47 PM
owc6's Avatar
owc6
@fyreline I have a SmartTOP that used to be in my P.E. Vert that I would like to sell.
If you are interested, PM me. I'm on the road for another week ( started in June), but I can get to it after I get home.
lisa
Old Aug 2, 2021 | 03:40 PM
Spedee's Avatar
Spedee
PM sent
Old Aug 2, 2021 | 06:08 PM
yellow2007's Avatar
yellow2007
From what I understand about the smarttop is if you want the windows up feature that requires an additional module that has to be plugged in to the OBD port. If you are using a range device either you stop using it or buy a splitter to connect the range AND smarttop module. Imagine THAT hanging down under the dash..........I'll pass.
Old Aug 2, 2021 | 06:15 PM
eboggs_jkvl
Moderator emeritus
I do. I have. I use wire ties to keep it all up out of the way.
Elmer
Old Aug 2, 2021 | 06:33 PM
Spedee's Avatar
Spedee
No window module available for the 2019
Old Aug 2, 2021 | 10:20 PM
owc6's Avatar
owc6
Elmer
Oh,Boy, am I confused.
The 2014 version for the OP is under the waterfall with no wires visible anywhere.
Old Aug 3, 2021 | 07:38 AM
yellow2007's Avatar
yellow2007
The module under the dash is only for the windows up feature. The top down module does mount behind the waterfall.
Old Aug 3, 2021 | 08:15 AM
eboggs_jkvl
Moderator emeritus
Lisa,
There are two hunks of hardware for the Smarttop. Plug-in for the DTC and a module that plugs in under the waterfall. The water fall module controls the movement of the top and is well hidden but the DTC plug is in competition for the Range plug for the same hole. You get a short wired splitter to plug in two units into the same DTC slot. The splitter has a DTC fitting on each of the two ends and both the Range and Smarttop can be hooked up at the same time into the DTC.
Elmer
Old Aug 3, 2021 | 10:16 AM
owc6's Avatar
owc6
Ah, yes. NowI remember there is a part that plugs into the OBD port.
I have all the parts in a plastic bag in the basement where I put it two years ago, and haven't given it another thought.
To Remote top down function
