Transmission Relearn
Old Sep 16, 2022 | 04:48 PM
Har-ray's Avatar
Har-ray
I have found over the years;
If, when you first start the car, whether sitting overnight or just for 5 min., you shift from 1st to 2nd while stopped and then back to 1st, it doesn’t flair shift.
Old Sep 16, 2022 | 07:08 PM
Dcasole's Avatar
Dcasole
Ok .... thanks for sharing but .....
I can't vouch for this as I can't see how it would have anything to do with stopping shift flair
Old Sep 16, 2022 | 08:51 PM
BLDun's Avatar
BLDun
Quick question: Does any of this apply to the A6 in the 2014??
Old Sep 16, 2022 | 09:34 PM
Dcasole's Avatar
Dcasole
Yep A6 can shift flare as any adaptive transmission can . I had to do the garage relearn on my C6 A6 twice in 65,000 miles that I owned it
Dave
Old Sep 17, 2022 | 03:39 AM
jimtreber's Avatar
jimtreber
Yep, that works. I've done it on every cold start for a couple of years and have never had another repeat of the 1-2 shift flair.
Old May 25, 2024 | 02:31 PM
garywalsh's Avatar
garywalsh
Har-ray: What do you mean by a shift flair? Thanks
Never mind, I found the question and answer later on in this thread,
Old May 26, 2024 | 02:56 PM
garywalsh's Avatar
garywalsh
Hey Dave: What is the difference between a "fast Learn set up" and a "garage Learn"? My dealer performed the former in April , 2020 and the transmission ran fine until August, 2022 when the Hard Shift returned. I'm not going to ask them if they performed either at this point because I don't think they would be truthful. I'm taking it somewhere else for the new "relearn" procedure. Thanks for your help,
Gary Walsh
Old May 26, 2024 | 04:42 PM
Dcasole's Avatar
Dcasole
@garywalsh , back in the C6 days it was called a clear adapts /fast relearn which was nothing like the garage relearn process on the A8 . The name old name just stuck around .....
Dave
Old May 26, 2024 | 05:05 PM
garywalsh's Avatar
garywalsh
thank you, i am having issues with my computer so i wasn't sure if you received my message, i think you have saved me from making a big mistake. i will be eternally grateful.
Old May 26, 2024 | 05:15 PM
garywalsh's Avatar
garywalsh
Dave: I have researched this procedure and it looks like the test must be performed on an open road with adjustments being made as the transmission is put in different gears. It looks pretty involved. Can the procedure be performed in the shop (on a lift)? It looks like it could be a three or four hour process and cost upwards of $700. Can you opine on this aspect? Again, thank you very much for your help.
P.S. I have resolved my computer issues, thank God. I am under enough stress right now with the Corvette.
Old May 26, 2024 | 05:30 PM
Dcasole's Avatar
Dcasole
What i sent you was the manual process , thats not how I or a dealer or trans shop do it . We use a tool that will put the trans into the learning mode and the TCM will cycle almost the selonoids and measure release times all at once .the process takes less than an hour to complete . What your shop charges you ..... thats another story
I recommend going to a good Transmisson shop or a very competent repair shop and ask them what it would cost to do the Garage relearn on your car . Don't forget , you are going to need to drive it hard after it's done , babying it is what causes it in first place
No need to stress out ... its a car 😀
Good luck and let me know how it works out
Dave
Old May 30, 2024 | 07:34 PM
garywalsh's Avatar
garywalsh
Dave: I just got a call from (the second dealer) whom I took the car to get a second opinion. I asked them to do the relearn. I am not sure whether they did or not at this point but I was told the Stator Support does not bleed down. I seem to remember you mentioning this as another cause of concern for A8 owners. Does this sound logical to you? I the "relearn" was not performed, does it matter at this point? Thanks for your reply.
Old May 30, 2024 | 08:23 PM
  #33
Dcasole's Avatar
Dcasole
Gary , I have no idea what they are calling a "Stator" support ( and I know what a stator is) , and if they don't know what the drain back issue is , run , don't walk ...
Wow just feels like good dealers are few and far between
The TSB for this issue is here in this thread
https://www.corvetteforum.com/forums...rain-back.html
Also , tell them you are not "Asking" them to to the garage relearn, Tell them you want it done! Especially if they don't know what the drain back problem was .......
Dave
Old May 30, 2024 | 08:29 PM
  #34
Dcasole's Avatar
Dcasole
@garywalsh , Remember, the drainback issue TSB should be a last resort...
See Steve's email about doing the Garage relearn here
https://www.corvetteforum.com/forums...ion-fluid.html
Dave
