Nail in runflat
Old Aug 27, 2021 | 06:16 PM
Skid Row Joe's Avatar
Skid Row Joe
Originally Posted by sgt1372
I do NOT consider any Discount Tire franchise "necessarily" a competent tire store. It all depends on who is doing the work (not where you go to get the work done).
The BEST repair, as noted above, is a plug w/an attached patch, which requires the bead to be broken but does NOT require the tire to be removed entirely from the rim.
Any "competent" tire repair person can do this repair in just a few minutes.
Discount Tire Stores are NOT franchises. One family in Arizona OWNS ALL 1,100+ stores. They, as other tire stores can and do make mistakes - a lot of them. You've got to watch them AND check their work. Same as at any tire fix it shop.
Old Aug 27, 2021 | 06:21 PM
Skid Row Joe
Originally Posted by gliot1
Good luck if the tire must be replaced. Michelin customer service sucks....it can take as much as 6 mos to get a Corvette replacement tire. I switched to Continentals.
Really....??!
Depends on who you buy em from. Discount Tire Stores have provided on-the-spot replacement and adjustments to ALL Michelin tires I've brought them for over 25 years.
Who'd you buy your Michelins from??
Old Aug 27, 2021 | 08:26 PM
Bill Dearborn's Avatar
Bill Dearborn
It isn't about Discount Tire being competent. It is about them being willing to actually do the work. A lot of shops just say they won't patch run flat tires or Z speed rated tires. Just flat out refuse to even look at them. They just say the tires can't be patched and that is where the confusion starts with some people then believing the tires can't be patched.
Bill
Old Aug 28, 2021 | 02:23 AM
Chomorro's Avatar
Chomorro
I just got my rear grand sport run flat plugged. I had them remove the tire and patch it from the inside. They scuffed it up with a sander. They ended up breaking my tpms sensor and I had to go back so they could replace it. But over all $25 for the patch job and I requested they be very careful with the ccb rotors and they were.
Old Aug 28, 2021 | 07:02 AM
slant6's Avatar
slant6
Little things like this make me want to leave the tire on and plug it myself
Old Aug 28, 2021 | 08:48 AM
CraigStu's Avatar
CraigStu
20+ years as a Lexus tech I have plugged 100s of tires. When they first started using run flats they were insistent that we remove the tire and patch it from the inside. After a couple years of owners complaints because we charged $100 they relaxed the rules. By year 3 or so we were plugging them just like any other tire of course as long as the nail was in an appropriate place. We used the brown worms like the Safety Seal mentioned above. Here is my tip. Forget the hand powered reamers and use your drill w/ a 3/16 to 1/4 inch bit. Just in and up and down maybe 3 times. Also use tire patch glue. I would glob some on the hole and then slather it all over the plug. Slop it on and quickly insert the plug. The glue acts as a lube as long as you do it quickly before it starts to set up. Shove it in until 1/4 inch of the plug remains visible. Remove the tool and trim off the 1/4 inch w/ a razor blade. I probably wouldn't run a plugged tire on a track but I have autocrossed on a plug w/ no problems. Believe me, w/ the Lexus emphasis on customer satisfaction, if these plugs didn't work we would not have been using them.
Old Aug 28, 2021 | 11:34 AM
slant6's Avatar
slant6
Thanks,I think I will go that way
Old Aug 28, 2021 | 12:50 PM
SingleTrackMinded's Avatar
SingleTrackMinded
I had a screw in my tire back in 2018. Removed the tire myself and took it to the nearby Discount Tire. They plugged the tire and no charge. I gave them a tip. Tire and plug have been fine since then.
Old Aug 28, 2021 | 02:56 PM
nmerhaut's Avatar
nmerhaut
Had a piece of rebar ruin tire and wheel in May up in Michigan and Discount Tire had a new tire for me in 2 days and Bob's Wheels had a new wheel to me in 2 days. I thought the shortage on these tires was over.
Old Aug 28, 2021 | 03:01 PM
nmerhaut's Avatar
nmerhaut
I have run plugged RFs on a track and never had a problem.
Old Aug 28, 2021 | 03:10 PM
ZO6 cracker's Avatar
ZO6 cracker
I just got a issue with driver side rear tire. Everything was fine driving to Carlise on Thursday for the show. Tire pressure was good before I left. When I left Carlise noticed on my tire gauge in the car the rear was down 5 lbs. pulled the wheel today to try and find leak looks like I picked up a very small hole on the tread and tire monitor gauge looks like there maybe some bubbles around that also. Sprayed them with soapy water. Stopped at the dealer I bought it from going to work today. Going to drop wheel off next week and have them fix it. It’s covered under warranty.
Old Aug 28, 2021 | 03:41 PM
slant6's Avatar
slant6
A nail in tire is covered under warranty?
Old Aug 28, 2021 | 04:05 PM
  #33
ZO6 cracker
I have the road hazard warranty with my Z06.
Old Aug 28, 2021 | 05:03 PM
  #34
Rags6659's Avatar
Rags6659
I just had that problem 3 weeks or so ago. I plugged it myself with a plug kit I bought at Walmart for 7 dollars. Not one pressure problem since. I set my display on tire pressures for awhile and everything was fine.
Old Aug 31, 2021 | 08:29 AM
  #35
ZO6 cracker
We’ll just got the news this morning after dropping off my rear tire on my 19Z06. Did fine a small nail in it. The dealer said they cannot patch it. They will be getting me a new tire under my warranty I’m fine with that. I rather a new tire.
Old Sep 1, 2021 | 10:52 AM
  #36
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
A plug is fine, even though not a runflat, racers plug slicks all the time and run them at speed with absolutely no issues. You'll be fine.
Old Sep 1, 2021 | 01:49 PM
  #37
slant6's Avatar
slant6
as it happens drove car few days ago and pushed nail further in tire and now is not leaking.
New question, can I leave it?
To Nail in runflat
Old Sep 1, 2021 | 02:04 PM
  #38
Pro69ss's Avatar
Pro69ss
It will leak again at some point .
I would attempt to plug it your self .
A patch works great of done correctly but the tire has to come off the rim , sometimes damaging the tires beads , the spot has to be ground down inside the tire and if a cord is exposed ( happens frequently) the tire is trash as it will always leak .
Plug it or replace it .
if replaced buy a road hazard warranty.
Old Sep 1, 2021 | 02:07 PM
  #39
Walt White Coupe's Avatar
Walt White Coupe
I'd bet that if you put some soapy water on it, it would bubble indicating a slow leak.
Old Sep 1, 2021 | 05:53 PM
  #40
slant6's Avatar
slant6
I did no bubbles
