C7 engine
Old Aug 28, 2021 | 01:12 PM
h17dragon's Avatar
h17dragon
4th Gear
Default C7 engine
New to the forum,
I’m looking for a rebuilt engine for my 2014. This will be engine number 4. First and second engine, dropped valves, third engine locked up.
Any recommendations would be appreciated.
Old Aug 28, 2021 | 01:32 PM
4thC4at60's Avatar
4thC4at60
At the rate you're going could have bought a replacement from Chevy for a lot less money than you're spending. I'd take it to Chevy dealer and be done with it..... seven Vettes, 31 years 979,000+ mies....
Old Aug 28, 2021 | 01:55 PM
Skid Row Joe's Avatar
Skid Row Joe
LS6 in crate. With warranty
Old Aug 28, 2021 | 02:01 PM
vbb's Avatar
vbb
Ok, gotta ask... what kind of power are you running? That would be astonishing if you've been all stock and had 3 grenade on you!
Old Aug 28, 2021 | 02:13 PM
Jeff V.'s Avatar
Jeff V.
Um, whut?
Old Aug 28, 2021 | 03:28 PM
h17dragon's Avatar
h17dragon
4th Gear
Third engine cost $12,000 + at the dealer. That’s the one I’m replacing. I have zero faith in any dealer right now. Latest engine lasted 16000 miles
Old Aug 28, 2021 | 03:29 PM
h17dragon's Avatar
h17dragon
4th Gear
Stock engine
Old Aug 28, 2021 | 03:35 PM
h17dragon's Avatar
h17dragon
4th Gear
Yes, three engines. First at about 85000 miles dropped 2 valves. GM covered that one. Second engine went to 106000 miles. Dropped 4 valves. Out of warranty. Third engine has locked up at 121000 miles.
Old Aug 28, 2021 | 03:49 PM
The Successful Plumber's Avatar
Maybe you need to consider changing your driving and maintenance habits?
Old Aug 28, 2021 | 04:12 PM
It is HIGHLY unusual for someone to have to replace three engines - it is not like these things go around doing a complete failure all the time. Something just does not sound right.
However, if you are not doing something that leads to the engine failures, I would say it is time to find another car. That one is jinxed.
Old Aug 28, 2021 | 04:52 PM
vbb's Avatar
vbb
Agreed. That's weird. 3 engines completely grenading? Thats strange.
My suggestion to the OP would be to get a stock LT1 with low miles.
Old Aug 28, 2021 | 05:13 PM
jwmgr8's Avatar
jwmgr8
Weird?
If I were you I'd hire out to GM as a engine tester?
Old Aug 28, 2021 | 08:27 PM
RRC19966's Avatar
RRC19966
312,000 miles on a 2014? It's definitely not a garage queen. Don't think I could do that if I tried.
Old Aug 28, 2021 | 08:38 PM
Kevin A Jones's Avatar
Kevin A Jones
Something's just not right here. Cut your losses and get another car...........................
Old Aug 28, 2021 | 08:50 PM
Elk's Avatar
Elk
IF this is real, there is a great deal more to the story.
Old Aug 29, 2021 | 12:55 AM
Skid Row Joe
Buy an LS6, and be done with it.👍
Old Aug 29, 2021 | 07:39 AM
madrob2020's Avatar
madrob2020
You must have started drinking early 🥃. I think he was pointing out the miles BETWEEN each engine catastrophe, not a total of over 300K miles total on the CAR. Still a very impressive number of miles he’s driven in about 7-8 yrs.👍
To C7 engine
Old Aug 29, 2021 | 07:50 AM
99vetteran's Avatar
99vetteran
Why would you recommend an Ls6 port injected motor from the C6 platform? Don't drink and post ok. Haha.
Old Aug 29, 2021 | 07:53 AM
the blur's Avatar
the blur
Sell the F-in car & move on. It's like dumping money into an ex-wife.
Old Aug 29, 2021 | 08:01 AM
Purple92's Avatar
Purple92
So when valves" drop" it's generally either:
Valve Spring Failure
Valve Spring Retainer / Lock failure
The Valve itself Failing (breaking).
I've seen each of these, and I've never seen an engine where multiple valves are "dropped" at the same time. So, my question is what RPM were you at when these multiple valve drops happened ???
As for what to do now - I don't believe that LS6 Crate engines are available any more. I know the LS6 Block is no longer available. (And honestly - the LS6's had issues with valve spring failures - so even with a brand new LS6 motor - I would change the valve springs before installing it.) If I were in your position, I would go to a reputable race engine builder, and have him look at your current engine (the one that locked up), and see if he thinks it's rebuildable / salvageable. If it is - have it rebuilt for "endurance" application (not high power or competition use). I would highly recommend going with wiih quality double valve springs, and then have a tuner reprogram the PCM to limit red line to around 5,500. (And if you enjoy downshifting to slow the car - I's suggest that you Don't Do That).
