TPMS Oddity
Old Sep 1, 2021 | 01:13 PM
JMoore5196's Avatar
JMoore5196
Default TPMS Oddity
I have a 2014 Z51. Last night marked the start of my first real road trip in the car, and the 'Service TPMS System' message appeared about 30 miles into the trip.
I switched the DIC to view the tire pressures. The two tires on the passenger side showed normal readings; the two on the driver's side were unavailable.
About 5 minutes later, the back passenger side tire became 'unavailable' as well, and the front passenger side tire flitted in and out as I drove through the evening.
The tire pressures are fine, but the system can't be reset. I followed the procedure listed elsewhere on the forum several times without a different result; the idiot light and error message remain.
I think the odds of three sensors failing at the same time are astronomically high, but I imagine that's the story I'll get when I take the car to the dealer.
The system has been trouble-free until now. Anyone have a guess what the problem might be?
Old Sep 1, 2021 | 02:23 PM
Vette Ski's Avatar
Vette Ski
Have you added any side marker or any other lights to your car recently ?
Rich
Old Sep 1, 2021 | 04:18 PM
JMoore5196's Avatar
JMoore5196
No; I should have mentioned that other than Infotainment modules to add CarPlay functionality, the car is absolutely stock.
Thanks for playing!
Old Sep 1, 2021 | 04:37 PM
miami08VETTE's Avatar
miami08VETTE
This sounds crazy but I have found most "odd" issues like this benefit from disconnecting the battery for a few hours. I've had a few instances where things cleared up. It's a quick and free diagnostic step. YMMV. Good luck.
Old Sep 1, 2021 | 05:00 PM
LT4CMG's Avatar
LT4CMG
Easiest step is disconnecting the battery, as mentioned above. Something else to consider is the age of your TPMS. Battery life in those vary wildly, as little as 5 to as long as 15 years.
Old Sep 1, 2021 | 05:23 PM
JMoore5196's Avatar
JMoore5196
I know the sensors are aging, but the odds against all of them playing up at the same time seem pretty steep to me.
I'll certainly try disconnecting the battery and see what happens. Thanks!
Old Sep 1, 2021 | 05:28 PM
Bill Dearborn's Avatar
Bill Dearborn
How long since your car was put into service. With a 2014 I suspect you are running into issues with the TPMS sensor batteries reaching the end of life. Sensor readings that suddenly become unavailable are usually due to the sensors being dead or the transmitted signal strength not being strong enough to reach the antenna on the car. Programming the TPMS programs the car to recognize the sensors, if there was an issue with the car side of the TPMS you would not be able to intermittently read the one sensor still sending signals to the car. You probably should do some research to see how much a set of 4 sensors will cost you. I usually purchase my sensors from The House of Wheels as he has a very good price and is a forum sponsor.
Bill
Old Sep 1, 2021 | 06:22 PM
Grand Slam's Avatar
Grand Slam
When disconnecting the battery to reset things you only need to disconnect it for 10 minutes or so. Just long enough to let parasitic charges dissipate.
Old Sep 2, 2021 | 12:14 PM
If the battery disconnect doesn’t solve the problem, it very well may be the sensors themselves at the end of their life cycle. May be time for some new ones.
Old Sep 2, 2021 | 01:09 PM
Walt White Coupe's Avatar
Walt White Coupe
And they can be replaced by just "breaking the bead" without removing the tire from the wheel.
Old Sep 3, 2021 | 11:33 AM
JMoore5196's Avatar
JMoore5196
The battery disconnect didn't help matters.
The dealer says only one sensor can actually be 'read' by their tool. I'm going to order a set from HoW and have them replaced.
I'll let you guys know if the problem persists. Thanks for your input!
Old Sep 3, 2021 | 01:07 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Even if your sensors aren't actually at the end of their life, they're old enough now that replacement makes sense.
Old Sep 13, 2021 | 10:22 AM
JMoore5196's Avatar
JMoore5196
Just a quick followup: I'm back at the dealer this morning, having all 4 sensors replaced. We'll see if that solves the problem. If it doesn't, I'll report back.
Incidentally, I bought the new sensors from House of Wheels and managed to get them in a week, despite the long Labor Day weekend.
Thanks for all the guidance. I'm always grateful for the resource that is CF.
To TPMS Oddity
