Settings Icon Disappeared
Old Sep 24, 2021 | 07:34 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Default Settings Icon Disappeared
My settings icon disappeared from my screen. Anybody know how to bring it back?
Old Sep 24, 2021 | 08:25 PM
ErnieN85's Avatar
ErnieN85
Happened to me last week a hard reset fixed it
remove battery cables short them together for a few min. Then put them back on the battery.
Hope this works for you
Old Sep 25, 2021 | 11:48 AM
Grand Slam's Avatar
Grand Slam
First make sure it hasn't moved to a different page by swiping the page. Then you could try the reset.
Old Sep 25, 2021 | 12:08 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Information I had is incorrect. Removed data.
Elmer
Old Sep 25, 2021 | 03:16 PM
Rky Mtn C6's Avatar
Rky Mtn C6
Originally Posted by eboggs_jkvl
I felt energetic and looked them up for you!
Engine Bay Fuse Box
2014 is #52
2015 is #53
2016 is #53
2017 is #53
2018 is #53
2019 is #52
Elmer
Thank you Sir, but it didn't work.
Old Sep 25, 2021 | 06:14 PM
Elk's Avatar
Elk
To do the ALT-CTRL-DEL to the car, use your owner's manual to find the location of your ECM/TCM fuse . . .
How is resetting the engine control module and transmission control module going to change how the Settings icon behaves?
Does pulling the ECM/TCM fuse effect more than these two modules?
Old Sep 25, 2021 | 11:31 PM
Goat 2 Vette's Avatar
Goat 2 Vette
Its telling you its time to trade your Vette in for a Mustang.. :P
Old Sep 25, 2021 | 11:41 PM
legacypgmr's Avatar
legacypgmr
The OP isn't complaining about how the "Settings" icon behaves.
He can't FIND the Settings icon. It's disappeared.
Old Sep 25, 2021 | 11:49 PM
Elk's Avatar
Elk
Yes, and disappearing is a behavior - although this is absolutely silly to argue about.
But this is not my query in any event. I am asking how resetting the engine control module and transmission control module is going to have any impact on the Settings icon.
Do you know?
Old Sep 26, 2021 | 03:37 AM
eboggs_jkvl
Moderator emeritus
Edit
Old Sep 26, 2021 | 06:25 AM
ErnieN85's Avatar
ErnieN85
The fuse pull has the same effect as disconnecting the battery. It's a reboot of the electronic system.
Someone said that a reboot might "find" the "Settings" icon. I felt this fuse pull was easier than the cable disconnect.
Elmer
Elmer, I was corrected about that there are many capacitors that hold a charge and the system will not completely reset without shorting the two camles long enough to drain them so yes it is different from just pulling a fuse
Old Sep 26, 2021 | 09:27 AM
eboggs_jkvl
Moderator emeritus
Well, crap. I'll edit my notes and correct my post.
Elmer
Old Sep 26, 2021 | 10:18 AM
legacypgmr's Avatar
legacypgmr
Do you know?
"Disappearing is a behavior". Nice try.
But no, I don't know how resetting ONLY those 2 modules would have any impact in this case. That said, the hip bone is connected to the thigh bone and the thigh bone is connected to,,,,,,,,,,,,,,,,,,,,, etc.
I COULD (generally) explain how resetting a device containing computer chips can/may restore behaviors but you probably know that yourself.
Old Sep 26, 2021 | 11:45 AM
eboggs_jkvl
Moderator emeritus
Thank you,
Elmer
Old Oct 19, 2021 | 04:10 PM
Rky Mtn C6's Avatar
Rky Mtn C6
UPDATE: Took it to the dealership and they couldn't figure it out. They were on the phone to Chevy & GM, and their best guess was to change the HIM (Human Input Module). They did it, reprogramed it, and the icon is now back where it was.
Old Oct 19, 2021 | 04:49 PM
eboggs_jkvl
Moderator emeritus
So, you killed your human in the car! You are deadly!
I'm glad the dealer and GM could figure it out.
Elmer
Old Oct 19, 2021 | 05:39 PM
Elk's Avatar
Elk
Excellent news!
I am glad they figured it out, but it certainly took a bit of work and time.
Thanks for letting us know.
Old Oct 20, 2021 | 05:59 AM
Glad the dealership was able to get things back to normal.
To Settings Icon Disappeared
