Flashing Check Engine Light
Old Oct 8, 2021 | 07:53 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Flashing Check Engine Light
We’re on a road trip in a semi boondocks area. Yesterday we’d been driving for a couple of hours, going eabout 45 mph on a country road. Suddenly I noticed the Check Engine light was on. A couple of seconds later it started flashing. Flashed for about 10 seconds, then went out. We drove about 15 minutes more to the hotel without any problems. Lots of driving planned for the next 4 days. No dealer nearby.
All engine readings were normal and the car felt perfectly normal while the light was flashing and afterwards for the remaining 15 minutes. Car has never done anything like this before.
Car is a 2017 Z51 A8. Totally stock, 42k miles.
Predictions?
Old Oct 8, 2021 | 08:00 AM
kiki 1's Avatar
kiki 1
Hmmm flashing engine light usually means a missfire, but you had no miss.
Old Oct 8, 2021 | 08:03 AM
kiki 1's Avatar
kiki 1
Are you near some shop that could see if you have any stored codes that may have caused the light to flash?
Old Oct 8, 2021 | 08:29 AM
Gearhead Jim
St. Jude Donor '13
Going to a shop or dealer will take us out of our schedule enough to ruin the trip. I’m inclined to keep going so long as it’s running normally.
Old Oct 8, 2021 | 08:34 AM
vbb's Avatar
vbb
Without pulling a code, there is no way to tell what that was. If you will come near any type of auto parts store, pick up a cheap OBD II scanner and pull the codes yourself. But it sounds like you've made up your mind to keep going with the trip, so good luck!
Usually a flashing CEL is the worst, and suggests that there is a misfire as someone already stated or some other major problem. The fact that it went away, hasn't come back and your car is operating normally are all good signs. I guess worst case scenario, in this day of cell phones and roadside service, if your car should have some sort of catastrophic failure, at least you can get to safety pretty quickly. I would imagine that you're taking all paved roads and highways, so this isn't some "overlanding" trip out in the woods.
Old Oct 8, 2021 | 08:42 AM
Let It Ride's Avatar
Let It Ride
Call Onstar from the car, can't they read the codes?
Old Oct 8, 2021 | 08:52 AM
Gearhead Jim
St. Jude Donor '13
We don’t have the Onstar subscription, could we still get the info ?
We will be on paved roads, not sure of cell service but another vette traveling with us so they could go get help.
Old Oct 8, 2021 | 09:03 AM
seniorstorekeeper's Avatar
seniorstorekeeper
If you pass by a Walmart, they have a code reader that I bought for my use, it was about $30. It will read codes and reset them, might be worth a stop if one is on your route.
Old Oct 8, 2021 | 09:04 AM
joemessman's Avatar
joemessman
Please be careful. This means that the engine is possibly dumping unburned fuel into your vehicle's exhaust system. ... It could even start a fire in your vehicle.
Old Oct 8, 2021 | 09:26 AM
RonC7's Avatar
RonC7
Check that your spark plug wires are tight. I recall reading that a misfire / check engine was caused by a poor spark plug wire connection.
GL
Ron
Old Oct 8, 2021 | 10:01 AM
vbb's Avatar
vbb
This is a good suggestion. I know OP stated that detouring to a dealership would be too far out of the way and ruin the trip, but surely he isn't so remote that a Walmart won't be somewhere less than 30 minutes out of the way. I would need the peace of mind to pull the codes in order to be comfortable if it were me. Being nervous driving along some super remote stretches of highway with a car that had a flashing CEL would ruin my trip a lot quicker than detouring a few miles out of my way to find a code reader.
Old Oct 8, 2021 | 10:35 AM
Red Alert's Avatar
Red Alert
I also recommend getting an OBDII reader. If that's not possible, any semi-modern car repair service shop will have an OBD reader. They can pull the codes for free or no more than a small charge. You can look up the meaning of the codes on any internet connection.
Old Oct 8, 2021 | 02:04 PM
Dcasole's Avatar
Dcasole
This ...... ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ its better to stop now because if IT stops later its not going to be good and you will wish you stopped
a flashing Check Engine light is bad
Dave
Old Oct 8, 2021 | 02:16 PM
rhneff's Avatar
rhneff
With the engine running, raise the hood and listen for a slight "ticking" sound. If you hear that, stop your trip immediately and take the car to the closest Chevy dealer.
Just had a very similar experience with wife's Suburban, CEL would flash, then stop. She ignored it for awhile before telling me, when I looked at the truck I could hear a slight ticking at idle. Had to do with a failure in the Active Fuel Management/AFM/DOD system. Resulting repairs were close to $4,000 (fortunately covered under extended warranty).
I've attached the GM Service Bulletin describing the symptoms, in-progress failure and corrective action that was done on the Suburban, and you'll note that the Corvette is included in the bulletin.
File Type: pdf
Old Oct 8, 2021 | 06:15 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
OP;
"Why is my check engine light on?"
"Step 1- Obtain codes.
Step 2-Check your gas and gas cap. Remove the gas cap and put it back on, turning it until it clicks three times, then wait 24 hours to see if the code resets. A loose radiator cap can also trigger the check engine light.
Step3-Check the oxygen sensor. They are the most common causes of check engine lights coming on. Many owners have reported this problem popping up after they have an aftermarket exhaust installed."
Source- By Brett Foot- February 23, 2015
Many thanks,
Ray
Old Oct 8, 2021 | 10:15 PM
Thanks for the service bulletin and the other suggestions for solving this problem. OP - hope you get it identified and resolved soon and continue to enjoy your trip.
Old Oct 9, 2021 | 01:06 AM
96GS#007's Avatar
96GS#007
GL
Ron
The fact that it went out suggests a loose connection. Check the plug wires at the coils and the plugs. Sorry to say getting to the 4 plugs on the passenger side will be next to impossible due to the fuse box, but at least you can check the wires at the coils on that side.
To Flashing Check Engine Light
Old Oct 11, 2021 | 09:39 PM
Gearhead Jim
St. Jude Donor '13
We're home now.
Since the light appeared/disappeared, we put about another 700 miles on the car at a wide range of speeds and throttle. The light has not come back, and the car continues to run perfectly.
Tomorrow I'll call the dealership and see if they want me to bring it in now, or wait until my oil change appointment next week.
Thanks for all the comments.
Old Oct 11, 2021 | 09:41 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Originally Posted by Rayland
OP;
Many thanks,
Ray
C7 doesn't have a gas cap
Old Oct 12, 2021 | 07:12 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
We're home now.
Good to hear. I guess one time is an anomaly, more than that, an issue. Hope yours was the former.
