Paddle Shift vs Automatic Mode
Old Oct 9, 2021 | 09:27 PM
dbj216's Avatar
dbj216
Default Paddle Shift vs Automatic Mode
I'm sure am enjoying driving my 17 GS. No cracked wheels yet. I've been learning to drive with my A8 in manual mode and paddle shifting myself. Lazy driving usually keeping the revs between 2k and 3k rpm. Just neighborhood driving. I downshift into corners and zoom up the hills. It is great fun. I'm getting better at it. My mileage for a tank of fuel is about 15 mpg.
So after my my covid booster shot, I was feeling quite tired. I just put the Corvette in "D" and drove that way so I didn't have to think near as much. The Corvette is a completely different driving experience this way. I was surprised. And my mileage has improved to 18 mpg per tank. The revs are usually in the 1500 rpm range, even climbing the steep hills around here. Corvette knows how to maximize efficiency when desired.
This is my first automatic sports car. Manual shifting is more fun for me. I would likely prefer the M7. But having the manual paddle shifting performance and then the automatic relaxed driving is almost like having two cars in one.
Maybe you folks feel the same way.
David
Old Oct 9, 2021 | 11:31 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Hold the left paddle down firm. It will shift into the lowest possible gear.
When in Sport mode over 35-40mph, give the throttle a quick blip while watching your DIC. A message stating "performance shift active" then mash on it.
I sent my TCM out for a tune on my 19. 100% better at WOT
Old Oct 10, 2021 | 07:34 AM
Bill Dearborn's Avatar
Bill Dearborn
I have an M7 Z06 and when driving around town I keep engine speed in the 1000 to 1500 rpm range. The car runs great that way. Even when running at 40 mph in 6th gear there is no need to downshift to pass another car. Just floor the pedal and it shoots ahead. On one cool day, I was running about 45 mph in 5th, punched the throttle and spun the rear tires.
Bill
Old Oct 10, 2021 | 07:55 AM
Corgidog1's Avatar
Corgidog1
David
I liked your description of your experience, but it sounds like you really wanted the M7 and are making the best of your automatic.
Old Oct 10, 2021 | 08:05 AM
jwmgr8's Avatar
jwmgr8
It is interesting how many cars now have Paddle Shift.
I too have a 17 GS with an A8. The last two Corvettes have been A8's. I like automatic because I'm an old guy and get wore out shifting if I'm on long drive. I have second guessed myself because after all it is a sports car and shouldn't a sports car be standard shift?
From what I understand you can not get a C8 in Manual?
I am curious about your tracking gas mileage? I also thought gas mileage was not a consideration when buying a sports car? but I guess I'm wrong.
One more comment concerning automatic transmissions- I think they all have too many gears? and 8 speed seems excessive? my 2020 Mustang has 10 gears? way too many. I'd prefer they go back to something simplier like 5 or 6 gears? Focus on getting power to ground and smoothly shift from gear to gear? As it is the computer controls shifting gears. It just seems like it shifts alot? And the shifting is focused on gas mileage not driving experience.
Regardless- drive the car have fun and be safe. NO STREET RACING go to the track
Old Oct 10, 2021 | 08:27 AM
I have been using the paddle shifters on my A6 tranny more often than I used to - it does make driving a bit more engaging.
Old Oct 10, 2021 | 08:35 AM
yellow2007's Avatar
yellow2007
I rarely use the paddles unless I want to hear the exhaust "gurgle" when letting off the gas. It's not now and never will be the same experience as having that third peddle. IMHO
Old Oct 10, 2021 | 03:19 PM
je1689_12311's Avatar
je1689_12311
There are a few good reasons for having more gears - in short, more gears = more faster and more efficient-er.
There are complications to this, as anything, but theoretically if one's goal is to maximize acceleration, holding the engine at it's peak power is one of the better ways to do it. More gears allows closer ratios, which means smaller jumps in rpm when shifting, keeping it closer to the sweet spot.
Emissions/regulations is likely a bigger cause for this growth in gearing - just as it allows the engine to be held nearer peak power, when cruising it keeps engine rpm low, improving efficiency and playing kind with emissions regulations.
I'm sure there are a bunch of other considerations I'm not taking into account.
To Paddle Shift vs Automatic Mode
