A8 Paddled Shift Lag Possible "Fix?"
Old Oct 13, 2021 | 05:04 PM
stevettec7's Avatar
stevettec7
Default A8 Paddled Shift Lag Possible "Fix?"
As many owners that have used the manual paddles in their auto trans C7 know, there is a lag in the actual shift when using the paddles. Recently, after replacing my steering wheel with a manual version, I decided to paint the paddles for a little visual "pop" AND to cover the "Rev Match" lettering. When I took it out for the first test ride to check all the functions, I swear it shifts faster now. I was expecting the same lag but it wasn't there. When time permits, I'm planning to put a multimeter on my original paddles just to see if there's any lag in connectivity. I'll follow up once I've done that.
Old Oct 13, 2021 | 05:19 PM
Can’t see how what you did would improve anything other than the looks of the paddles, but if you think it helped, that’s what matters.
Old Oct 13, 2021 | 05:53 PM
Elk's Avatar
Elk
Agreed. There is absolutely nothing wrong with a placebo.
Old Oct 13, 2021 | 07:16 PM
stevettec7's Avatar
stevettec7
You're probably right. I'm probably being hopeful - and the internal switches for the manual vs auto paddles are probably identical, but it sure feels quicker. If I had nothing but time on my hands, I'd pull the manual paddles back out to do some true side-by-side tests with the meter. Right now we could all talk theory 'til the cows come home...and that's all it would be.
Old Oct 13, 2021 | 07:31 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
It seems to me, as long as I keep the R's up, I do not have it lag.
Old Oct 13, 2021 | 07:34 PM
4thC4at60's Avatar
4thC4at60
Agree!
Take the time to learn the lag.... then, shift when you'll be needing it... this isn't hard to learn.... I dove my C6 128,000 miles - learned the lag by going out and driving the car. Same thing applied in my '19 - lag was a bit shorter so even easier to figure out... SPEND TIME WITH YOUR CAR... no other solution needed.
Old Oct 13, 2021 | 08:30 PM
stevettec7's Avatar
stevettec7
Now that I think about it, I WAS driving pretty “spirited.” 😬
Old Oct 14, 2021 | 09:30 AM
joemessman's Avatar
joemessman
When I snap mine into performance shift mode (I think those are the words I see on the DIC) there is no lag at all. Puttering around town using the paddle shifters there is a noticeable lag, but who cares under those circumstance.
To A8 Paddled Shift Lag Possible "Fix?"
