Tpms
Old Oct 17, 2021 | 09:24 AM
olelucky's Avatar
olelucky
Default Tpms
So I put new wheels, tires, and TPMS sensors. I’ve tried the relearn a couple of times. This morning I did a 50 mile run just trying to do the relearn. No success. Is there a way to do them manually? I have the tool from my c6 days.
2019 grand sport.
Old Oct 17, 2021 | 10:35 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If you have the correct part number, they will relearn quickly.
The C7 sensors have:
GM part# 13581560 2014 - 2017
GM part# 13598775 2018 - 2019.
Tire Rack sells Shrader 20223 for 2014 - 2019.
Rock Auto sells the Shrader 20223 for $22.79
The C7 tire pressure sensors transmit their data to the TPMS module on a frequency of 433MHz.
1. start car - actual engine running - not the Acc mode
2. Select the tire pressure display in the DIC.
3. Press and hold the SEL button until the display changes and the horn beeps. It now says it's in learn mode.
4. Now drive just as it says in the manual - 10 min or so above 12 mph.
5. Suddenly, it will find all 4 sensors and show pressure
6. when you shut the car off , the "learn DIC" will show again and horn beeps.
Elmer
Old Oct 18, 2021 | 07:37 AM
What Elmer said. Hopefully you got the right sensors installed.
Old Oct 18, 2021 | 08:49 AM
CraigStu's Avatar
CraigStu
1.5 yrs ago I bought tires, wheels, and sensors all mounted and balanced from Tire Rack. I installed them on the car and went for a test drive. I got back home 30 min later and realized I had never seen any warning lights re; tpms. Since then I swap tires back and forth twice per month to run autocrosses and tpms system works perfectly w/ both sets. I suspect you have the wrong sensors.
Old Oct 18, 2021 | 10:49 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I purchased this based on another forum member recommendation and used it to reset all my sensors. Simple to use. Just make sure your battery is good.
VXDAS TPMS Relearn Tool for GM...
Amazon Amazon
Old Oct 18, 2021 | 11:41 AM
eboggs_jkvl
Moderator emeritus
VXDAS TPMS Relearn Tool for GM... https://www.amazon.com/dp/B072BK693N...p_mob_ap_share
Which brings me to ask what TPMS sensor units are you using on your car?
ELmer
Old Oct 18, 2021 | 12:54 PM
Wicked Weasel
ELmer
I dont know the name (they were sent with my new wheels) but the tire installer stated they were not OEM. Work fine (so far) and take all the same measurements as OEM.
Old Oct 18, 2021 | 07:39 PM
olelucky's Avatar
olelucky
I have that same tool, WW. When i got home, I set the car to learn mode, went to each tire and activated the tool. After the 4th wheel the car honked once. I think synced them. I haven't driven it yet to verify. Thanks for the replies. I will update when I drive it again.
I don't know the brand name of mine either. Ad says replaces
GM part# 13581560
GM part# 13598775
Old Oct 18, 2021 | 08:13 PM
Bill Dearborn's Avatar
Bill Dearborn
Elmer
When going to the track I just swap wheels and drive, the car learns the new sensors without doing anything else.
Bill
Old Oct 20, 2021 | 07:11 PM
olelucky's Avatar
olelucky
update: I made a few afternoon runs today. I still couldn't get them to sync. So I'll try to see if Discount tire can do it. I'm thinking these may not be for 2019 as stated in the ad.
Old Oct 20, 2021 | 08:04 PM
Mad*Max's Avatar
Mad*Max
Elmer
Old Oct 29, 2021 | 04:39 PM
olelucky's Avatar
olelucky
I talked to our local dealer yesterday. He said they could only program OEM sensors, and recommended a local tire shop. I went there today and they couldn't get then to sync with the car. So I made the 30 mile drive to my nearest Discount Tire shop. They were able to program them. However, on the way home the front left quit working. I made a stop to see my son, when I got back in, the front left was working. But now the front right stopped working. I'll work with them a little longer before I give up and change all the sensors. Does anyone know of a OEM gloss black sensor for the c7?
Old Oct 29, 2021 | 07:26 PM
olelucky's Avatar
olelucky
Mystery solved! I removed my AFM disabler, drove a short distance, and everything works as it should. Thank for all the suggestions and help.
To Tpms
