Storing C7
Old Oct 19, 2021 | 04:13 PM
ljorges's Avatar
ljorges
Default Storing C7
Hey guys,
Regretfully, some of us have to put our cars away in the winter. I’m in Chicago so winter time with the snow and salt is a no go for me.
Question: for those that do store their cars during the winter, do you fill up the gas tank or keep it almost empty? I’m in a non heated garage.
Les
Popular Reply
Oct 19, 2021, 04:18 PM
dvilin's Avatar
dvilin
Full tank no additives, pump up tires to 35 psi, hook up battery tender and wait for Spring weather to arrive.
Old Oct 19, 2021 | 04:14 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I fill it up and put in fuel stabilizer, R
Old Oct 19, 2021 | 04:18 PM
dvilin's Avatar
dvilin
Old Oct 19, 2021 | 04:22 PM
Red08's Avatar
Red08
I fill up the tank and put in Sta-Bil, put on the battery tender, throw on the cover, and I am ready to go. I usually add a few pounds of air to the tires. I also put some steel wool in the exhaust tips. I have doing this for many years, and have never had any kind of issues.
Old Oct 19, 2021 | 04:23 PM
The Successful Plumber's Avatar
The link in this thread from a couple of weeks ago says, NO. Store with 1/4 tank, so sending unit doesn’t get damaged by sulfur in fuel, if I remember correctly.
https://www.corvetteforum.com/forums...post1604136483
Old Oct 19, 2021 | 04:52 PM
Maxpowers's Avatar
Maxpowers
There is a link (in the link above) to a corvetteblogger vid that shows a chance of the fuel sensor failing. Probably a very slim chance with good (top tier fuel) but why risk it.
Old Oct 19, 2021 | 05:03 PM
C6_Racer_X's Avatar
C6_Racer_X
Add Techron concentrate plus complete fuel system treatment (or GM 88865595 or AC-Delco 10-3016) to a full tank of TopTier fuel (or ethanol free if you can get that). The Techron additive will coat and protect the fuel level sender from potential sulfur damage. There is a GM TSB that specifically recommends that additive as preventive care for the fuel level sender(s). If you put good gas in it, there shouldn't be an issue with sulfur.
If you store with low fuel, there can be other corrosion issues with the fuel sender.
For <6 months, I wouldn't bother with stabilizer.
For tires, I generally pump them up to the sidewall max pressure while stored. They can develop a settled "flat spot," and be a bit shaky when you first drive them in the spring, but that usually works itself out after the tires heat up. Higher pressure while stored helps to prevent that.
Old Oct 19, 2021 | 05:06 PM
Travlee's Avatar
Travlee
You can store it in my garage in Texas.....will start it up and drive it weekly for ya.....won't even charge ya.
Ha. I have nothing to add worth while, other than I am glad I give in the south
Old Oct 19, 2021 | 06:21 PM
ljorges's Avatar
ljorges
Haha. I appreciate the offer! Yeah these winters are getting less and less fun as I get older.
Old Oct 19, 2021 | 06:41 PM
ZO6 cracker's Avatar
ZO6 cracker
Just what dvilin said!! My same routine.
Old Oct 19, 2021 | 06:51 PM
joemessman's Avatar
joemessman
Why You Should Store Your C5/C6/C7 Corvette With Just a Quarter Tank of Fuel
https://www.corvetteblogger.com/2018/12/06/video-why-you-should-store-your-c5-c6-c7-corvette-with-just-a-quarter-tank-of-fuel/?utm_source=newsletter&utm_medium=email& utm_campaign=corvette_sales_news_lifesty le_daily_recap&utm_t
"The old reasons for storing with a full tank of gas no longer apply with the C7, c6, and C5.. The double sealed fuel filler neck and the charcoal canister on the other side of the tank prevent moisture build up from taking place."
Old Oct 19, 2021 | 06:54 PM
rfh928's Avatar
rfh928
From a fellow Canadian...same for me
Old Oct 19, 2021 | 08:29 PM
ArchitectMike's Avatar
ArchitectMike
A little more than 1/4 tank plus Stabil, then drive one last time down to 1/4 tank before detailing, covering and putting to bed for the winter. Plus you'll be ready for a full tank of fresh gas when the cover comes off next year.
Old Oct 19, 2021 | 08:39 PM
LT4CMG's Avatar
LT4CMG
Sadly, the time is getting near. I pump the tires to 40psi, put it on wheel cribs and leave a 1/4 tank of fuel. Cover it up and forget it exists for 5-6 months. I don’t put my Camaro away though, so that helps. As long as there’s no salt, I drive the Camaro.
Old Oct 19, 2021 | 08:52 PM
Bobtam's Avatar
Bobtam
Change oil and filter before putting it to bed want it to be stored with new oil. I’ve used Sta-Bil and a can of Seafoam in the tank for years with my C5 and now in my C7. Let it sit all winter do not start it unless your going for a long drive. Use a battery tender
Old Oct 19, 2021 | 11:24 PM
Kevin A Jones's Avatar
Kevin A Jones
Putting your C7 away for 4-5 months over the winter isn't storage but more extended parking and nothing needed except connecting tender to battery.
If it makes you feel better and don't mind wasting your time and $, by all means change your oil/filter, add fuel stabilizer, put carpet under the tires and wash and wax it.
By the way, modern tires don't flat spot, at least not to a point that driving a block won't correct. Now, old C1-C2 bias-ply tikes will flat spot.
Old Oct 19, 2021 | 11:30 PM
WPGZ06's Avatar
WPGZ06
I keep the tank full but otherwise the exact same routine.
To Storing C7
Old Oct 20, 2021 | 12:18 AM
LT4CMG's Avatar
LT4CMG
I used to keep it full, but recently switched to 1/4. One way or another, LS3, LT1, LT4, they all survive just fine. I put it up off the ground because in the spring, I just slide under and dump the oil and start the season with fresh oil.
Old Oct 20, 2021 | 05:47 AM
I have always added some air to the tires, put fresh oil/filter in the car, and added Sta-Bil and Techron to a full tank of gas. Never a problem, but as stated, some follow the advice of only storing the car with about 1/4 tank of gas.
Old Oct 20, 2021 | 10:19 AM
brocco's Avatar
brocco
Stop babying these cars, next there'll be questions as to what lullabies to sing to them.
