Help
Old Oct 31, 2021 | 07:24 PM
Keiths1969's Avatar
Keiths1969
Default Help
Went to crank car today and the car would not start, took battery out removed all cables and wires and took to Advance Auto and they did a rapid charge and said the battery was good.
I brought battery back home, put the battery in and now the engine light is on? I only let the car run a minute and the engine light would not go off
Would crossing the two red wires on the battery cause this? Please help
Old Oct 31, 2021 | 09:18 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Need to get the code read so we have a shot at an answer.
Elmer
Old Oct 31, 2021 | 09:54 PM
Keiths1969's Avatar
Keiths1969
How do I get a code read? It is just the yellow engine light?
Old Oct 31, 2021 | 10:00 PM
Frid's Avatar
Frid
St. Jude Donor '21-'22
You can take the car to an auto parts store like Autozone and they can have the code read to you for free.
Old Oct 31, 2021 | 11:33 PM
Avanti's Avatar
Avanti
Or, buy a cheapo reader and do it yourself. I think mine was $25 or so, and works fine with everything I've ever used it on. The reader's manual typically comes with most codes; others or additional details can be looked up online. Good luck with your issue.
Old Oct 31, 2021 | 11:46 PM
owc6's Avatar
owc6
Do you mean the check engine light was on after you started the car?
Not unusual at all, or dangerous unless the light is flashing.
Old Nov 1, 2021 | 01:37 AM
jimmbbo's Avatar
jimmbbo
A code reader in the glove compartment will give peace of mind in the event you get a Check Engine Light (CEL), as it illuminates for hundreds of reasons, and getting a CEL on a cross country trip produces anxious moments till you know what it has seen.
The reader plugs into the Onboard Diagnostic Code (OBD) port on the driver's side above the hood release. The OBD codes can be found at https://www.obd-codes.com/trouble_codes/ Many readers have the codes programmed into memory. YouTube has hundreds of videos on how to us OBD II readers/scanners
OBD II reader prices run the gamut depending on whether it's a reader or does deeper diagnostics. Amazon shows over 1000 readers available.
Old Nov 1, 2021 | 09:53 AM
seniorstorekeeper's Avatar
seniorstorekeeper
You can buy a HyperTough code reader at Walmart for about $25 dollars that will work. It will show the codes and let you reset it to turn the light off.
To Help
