Flood clear feature...
Old Nov 20, 2021 | 09:53 AM
Raidercop's Avatar
Raidercop
Default Flood clear feature...
Just watched a video on the C4-C7 feature called flood clear. You press the brake pedal and gas pedal all the way down then hit the start button. Your engine cranks without adding fuel so it clears it if its flooded. Then release the gas pedal and it starts right up. Also, a very good way to circulate oil after an oil change or winter slumber without damaging your engine. Maybe I'm just discovering something that everyone else already knew but being a newer C7 owner I found this feature to be helpful and wanted to pass it on.
Heres the video:
Old Nov 20, 2021 | 10:03 AM
dvilin's Avatar
dvilin
Thanks for sharing this has been posted before but a good refresher for those not always on the forum or new.
Old Nov 20, 2021 | 10:22 AM
aklim's Avatar
aklim
If the engine does not start and no DIC message is displayed, wait 15 seconds before trying again to let the cranking motor cool down. If the engine does not start after five to 10 seconds, especially in very cold weather (below −18 °C or 0 °F), it could be flooded with too much gasoline. Try pushing the accelerator pedal all the way to the floor while cranking for up to 15 seconds maximum. Wait at least 15 seconds between each try, to allow the cranking motor to cool down. When the engine starts, let go of the accelerator. If the vehicle starts briefly but then stops again, repeat these steps. This clears the extra gasoline from the engine.
I don't know anything about the brake pedal. My 16 manual doesn't mention it. Never heard of that for any car either but I could be wrong.
Old Nov 20, 2021 | 10:37 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Interesting, but, the C4 does not have a start button
Old Nov 20, 2021 | 10:43 AM
aklim's Avatar
aklim
Mine did. The PO tried to sell it as a "security feature". What happened was that the relay melted and rather than to do it right with cutting it all off, soldering in a new holder and all that, he decided to drill a hole and put a push button. So you turn the key to "run" and push the button so that if a thief comes, he won't know where it is, hence the "security feature". And if you believe that, I have a bridge to sell you.
Old Nov 20, 2021 | 11:17 AM
Maxpowers's Avatar
Maxpowers
Ive been here for a while and never heard of this. Interesting. Not sure you can flood a C7 but I may be wrong.
Old Nov 20, 2021 | 11:21 AM
aklim's Avatar
aklim
For whatever reason, GM seems to think it is possible. I copied that from my manual online.
Raidercop's Avatar
Raidercop
Here's the video demonstrating the feature:
Old Nov 20, 2021 | 03:22 PM
aklim's Avatar
aklim
https://youtu.be/TQgYU0EoZFc
IIRC, even back in the carb days, it was a "clear flood mode". It's been in every EFI car I owned. I quoted the manual above. It is even in my 2003 Seadoo GTX Supercharged where that is how you fog the cylinders. I don't know why you have to press the brake pedal. Nothing said about that in the manual
Old Nov 20, 2021 | 05:12 PM
Avanti's Avatar
Avanti
Great, but in practice... trivia the vast majority will never need.
Old Nov 21, 2021 | 10:23 PM
Tahoe's Avatar
Tahoe
Flood Mode discovered after I got tired of pulling the pump relay in my 2011 GS. 6 spd. Do you have to depress the brake pedal? It appears that I lost the Flood Mode function. Is there a fix?
Old Nov 21, 2021 | 10:29 PM
aklim's Avatar
aklim
A direct quote from my manual. Check your own manual online since you mentioned a C6
Old Nov 21, 2021 | 10:31 PM
robert miller's Avatar
robert miller
Default ttt
If your meth pump goes crazy & pump that **** & it get a ton on the plugs this c7 is not going to start. But per say I can see this car doing it unless a inj r so keeps pumping gas in on the plugs. But that is why now plugs can go 100,k miles... Robert
Old Nov 22, 2021 | 05:45 AM
449er's Avatar
449er
CF Community Team
This feature will work on a c6 also
Old Nov 22, 2021 | 07:15 AM
weathermaker's Avatar
weathermaker
I use this feature when I start the car for the first time in the Spring. However I don’t remember putting my foot on the brake. Maybe I do and just don’t remember it. OPS. (Old People ****).
Old Nov 22, 2021 | 02:25 PM
Tahoe's Avatar
Tahoe
My engine always starts. The question was about the loss of the Flood Mode function, which I use to prevent dry starts after car sits for a month. I definetly lost this function.
Old Nov 20, 2022 | 01:45 PM
JKU007FL's Avatar
JKU007FL
I know, old thread.
Is this "feature" useful after an oil change?
To Flood clear feature...
Old Nov 20, 2022 | 03:18 PM
Interesting video and learned something new today about the C4-C7 Corvettes. Thanks for posting this.
Old May 15, 2024 | 10:43 AM
Spacewalker's Avatar
Spacewalker
I know, old thread, but I was always. a big proponent of using Flood clear mode when starting my c6z that sits for long periods of time between being driven. It has always worked flawlessly. Yesterday however, the car started and revved to redline. The exact opposite of what I wanted.
so now I'm gun shy. Not sure how or why it happened -- but its really bothering me -- felt like abuse,
I didn't think it was supposed to start at all with throttle input. My foot was to the floor.
ugh.
Old May 15, 2024 | 11:56 AM
TraceZ's Avatar
TraceZ
FYI - this is nothing special to the C7. This has been standard function for fuel injected vehicles for decades.
My 1994 Camaro does this. - 30 years old.
