Correct battery?
Old Dec 17, 2021 | 08:23 AM
Catfish4818's Avatar
Catfish4818
Default Correct battery?
The battery in our 2015 (one week old, for us, today) has a 2020 date on it, which I'm happy to see. But, since I know that sometimes when things are changed, the new item is simply 'something that fits', versus being a correct replacement.
From what you can see in these photos, is this battery a correct replacement? And do the various cable and other wire connections appear to be done properly?
TIA, as always,
Larry
Old Dec 17, 2021 | 08:51 AM
Corgidog1's Avatar
Corgidog1
I googled this battery and it has a 30 month warranty. The OEM battery has a 42 mo. warranty I believe. Bottom line battery that I would replace.
Old Dec 17, 2021 | 09:08 AM
TJay74's Avatar
TJay74
So is the car starting correctly or not? Are you just trying to validate a way to spend $200 on another battery?
Old Dec 17, 2021 | 09:12 AM
Catfish4818
Nope, car starts fine, no problems, not looking for a new battery. I was just curious to know if the battery was replaced with a suitable unit, correct for the car, and if the cables and other harness connections appeared OK. So I guess, in other words, does what I have match what you all have?
Old Dec 17, 2021 | 02:08 PM
Corgidog1's Avatar
Corgidog1
No you do not have an OEM battery. Just a cheap battery that works.
Old Dec 17, 2021 | 02:18 PM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
Just remember, these cars are electronic nightmares...when the battery starts to go south, all sorts of gremlins appear, even if the car starts with no problems.
Old Dec 17, 2021 | 02:21 PM
Skid Row Joe's Avatar
Skid Row Joe
I believe they've eclipsed the $200.00 mark. +++ 😳 (AGM Diehard)
OP: I'm going with an AGM Diehard from an Advanced Auto Parts store. I've had damn good service/reliability/longevity AND CCAs - (Cranking Amps) from Diehards.
My 2006 Mercedes-Benz turbodiesel automobile has an AGM Diehard I installed in 2014 - still strong as h_ll and going strong.
I'm going to do a Diehard replacement in the 2017 Corvette myself. Wish us BOTH luck! Ha! 😄😉
There's tutorials ALL over You Tube on this......
Old Dec 17, 2021 | 02:26 PM
monicatomokc's Avatar
monicatomokc
Here's a pic of my dealer replacement battery from June 2020 and it looks like the same model/part number, but sticker just looks a little different. I recommend cleaning the rust off the neg battery terminal though.
Old Dec 17, 2021 | 02:28 PM
Skid Row Joe
Default ^^^^
Great input! Thanks 👍
Old Dec 17, 2021 | 02:39 PM
Kevin A Jones's Avatar
Kevin A Jones
As a bit of preventive maintenance, I'd recommend you shoot a little WD40 or similar product on the ground wire nut/stud in your second photo that looks rusted/corroded and clean it up a little.
I owned/operated a chain of auto parts stores for 16 years and a LARGE % of suspected battery issues are simply a corroded ground wire. That would concern me more than the existing battery.
Old Dec 17, 2021 | 02:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've always replaced the battery in our Corvettes at 3 years as a precaution. Living in the hot engine compartment and supplying the juice for a rolling computer puts a lot of demand on the battery.
On the C7, I'm willing to go 4 years because the battery is in a more temperate location.
If I owned your car, I'd keep that battery until 3 years or replace sooner it shows signs of age.
Old Dec 17, 2021 | 05:36 PM
CraigStu's Avatar
CraigStu
I am with Gearhead although I usually go 5 years. I was a BMW and then a Lexus dealer tech for the last 25 years. What I have noticed over the years is that batteries seem to die instantaneously. They don't really, but back in the day it took a bit of cranking to get a car engine to fire up. So, as the battery weakened, we could hear the engine crank over more slowly. That gave us some warning. Now modern engines crank up so quickly we don't ever hear a difference until it just doesn't crank at all. I have also had batteries that were tested OK but died 6 months later. So my feeling is that if a battery tests bad, it is bad. If it tests OK, it may be OK, but how long it's OK, is a question.
Old Dec 17, 2021 | 05:50 PM
RacerRik's Avatar
RacerRik
On a C7, since the battery is inside the car, to me the most important factor is venting. The OEM battery has vent tubes to run battery gasses / acid outside the car. A replacement battery should either have the vent tubes or be AGM, which require no venting tubes.
Old Dec 17, 2021 | 07:20 PM
Corgidog1's Avatar
Corgidog1
The OPs battery based upon the model number he gave is a AC Delco 30 month warranty battery, so I’d be careful after 30 months.
Old Dec 17, 2021 | 11:34 PM
Skid Row Joe
He's on borrowed time without changing it out.
My 2017 was manufactured in August 2016. I'm on gratis/grace time too....
Old Dec 17, 2021 | 11:51 PM
Vette junkie's Avatar
Vette junkie
Advance Auto Die Hard AGM is an EXACT replacement. It is a better and longer lasting replacement for OEM. It includes a vent tube like OEM.
Old Dec 17, 2021 | 11:56 PM
Skid Row Joe
Stated as such earlier in thread ^^^ I love AGM Diehards. They're about $225.00 plus tax, if anyone's wondering. Probably have a price increase in Jan. 2022. Get one now in 2021!
To Correct battery?
Old Dec 18, 2021 | 12:40 AM
4thC4at60's Avatar
4thC4at60
Nothing wrong with AC Delco batteries.... I have 31 years, 7 Vettes, and 979,000+ miles on OEM batteries.... My '15 OEM gave me 5.5 years --- car had more than 90,000 miles on it....
RMS73's Avatar
RMS73
I replaced my 2016's original battery last August with:
a Diehard: Group H6; 730 CCA; 910 CA; 115 Minute Reserve Capacity; 3 Year Free Replacement from Advance Auto
Your install looks ok except for the ground small eyelet connection. Looks like some corrosion or a corrosion resistant coating is showing.
Old Dec 18, 2021 | 12:42 AM
RMS73's Avatar
RMS73
My original label;
