Portable Inflator Recommendation
Old Dec 28, 2021 | 09:21 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Have couple similar to this that works great. Use them to maintain tire pressure on all our cars as well as put one in the car whenever we travel, just in case the spare is low...
VacLife Air Compressor
/JD
Old Dec 29, 2021 | 08:05 AM
shakinrock's Avatar
shakinrock
I do. I have a very slow leak that was undetectable by the tire shop and I'd rather add two lbs every other week than have them unmount and remount the tire.
Old Dec 29, 2021 | 08:32 AM
Toddster993's Avatar
Toddster993
I second the use of the hand held battery operated Ryobi. So far so good
its not quick but it’s small and light and cordless.
Old Dec 29, 2021 | 09:01 AM
joemessman's Avatar
joemessman
Here is one that fits easily in the cubby storage in back. And an added bonus is that it is accurate and easy to use. Just enter the air pounds you need and it automatically does it for you.
Amazon Amazon
Old Dec 29, 2021 | 09:30 AM
DGA3's Avatar
DGA3
I bought this one from Autozone (it was on sale: $4 off):
https://www.autozone.com/tire-repair...ght/989586_0_0
It works great!
Old Dec 29, 2021 | 09:39 AM
BLUE1972's Avatar
BLUE1972
Milwaukee M12 12-Volt Lithium-Ion Cordless Compact Inflator
Uses the M12 tool batteries and has worked for over 2 years.
NO Plug in required at the car or truck.
Old Dec 29, 2021 | 09:42 AM
64drvr's Avatar
64drvr
St. Jude Donor '15
I keep Viair compressors in all vehicles, sized appropriately for the need. I've used them pretty frequently over 5 years for various tasks and they still work like new.
70P (superseded by 85P) for car duty https://www.viaircorp.com/portables/85p
450P for truck/trailer duty https://www.viaircorp.com/portables/450p-rv-auto
Old Dec 29, 2021 | 10:22 AM
CB56's Avatar
CB56
I saved room when I ripped the plastic case off of my 12 volt air pump.
Old Dec 29, 2021 | 05:17 PM
Avanti's Avatar
Avanti
I have an older Walmart unit that I took everywhere... when our regular "good" compressor failed one year at B'ville, we used the little Walmart unit, and ended up lending it to a couple other teams close by that saw it. The thing may not have all the "features" you want, but still works like new last I checked. I've seen newer, fancier that quit working at all early-on. Sorry, I don't know the model specifics of any of them, but I'm sure mine's likely been superseded by now, anyway. But, just sayin'... one cannot necessarily judge these things by the price, and the simpler may be better from my experience.
Old Dec 30, 2021 | 09:35 AM
Corgidog1's Avatar
Corgidog1
Originally Posted by JMII
Huh?
try lighting a cigarette using that.......
Old Dec 30, 2021 | 11:24 AM
64drvr's Avatar
64drvr
St. Jude Donor '15
it is not a cigarette lighter but it is a 12v accessory socket which performs all functions of a legacy lighter except lighting cancer sticks
Old Dec 30, 2021 | 03:47 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Is the amperage rating too low to power a lighter?
I don't smoke but wonder how much power you can draw there.
Old Dec 30, 2021 | 04:05 PM
  #33
Skid Row Joe's Avatar
Skid Row Joe
I picked up a conventional tire pump from Walmart Supercenter bicycle department that works on all my vehicles, bicycle/unicycle. Doesn't need an oulet to operate either. Carry it with me when on a roadtrip.
Both of the cheezy-*** 12v outlet tire inflators (Harbor Freight cr@p...) I've bought over the years failed at some point, (both burnt-up/tilted on my 80 lbs. PSI RV tires.....) so I went back 60 years to the original tire inflator.....rated to 120 lbs. PSI. So, no more fails if I'm out in the boonies.
Old Dec 30, 2021 | 08:14 PM
  #34
jcwallace54's Avatar
jcwallace54
Originally Posted by Corgidog1
Since the C7s do not have a cigarette lighter, where do you plug it into?
My C7 (2019 GS) has a plug type outlet in a pop-up just forward of the shift lever.
Old Dec 31, 2021 | 11:29 AM
  #35
JMII's Avatar
JMII
This is my experience as well. My 50 PSI trailer tires have killed everything but the Viair unit I have now. The cheap-o plastic covered units are fine for the few PSI you lose monthly but if you have recover a total flat, fill bigger truck or SUV tires, or get something above 40 PSI you need a decent metal body inflator to handle the heat. I found this advice is spot on: https://www.nytimes.com/wirecutter/r...ire-inflators/
Old Jan 1, 2022 | 05:22 PM
  #36
Gearhead Jim
St. Jude Donor '13
How much of the trunk cubby does the Viair unit take up? The irregular shape makes it difficult to visualize how much room would be left over.
Thanks.
Old Jan 15, 2022 | 09:40 AM
  #37
Warpdrv's Avatar
Warpdrv
Banned Scam/Spammer
Lots of posts on this already, but I saw this on one of the YouTube Channels and thought it a good review though somewhat spendy....
But pretty Compact.....
Amazon Amazon
Along with the guys ZR1
