Kind of risky...if someone say hits you while the car is parked, it will damage your transmission. Having the brake will help protect it. I've driven mostly manual's for decades, and always use the parking brake without fail. You're doing the right thing!
Well, I'm in "P" when I park so how's that any riskier than using the PB and leaving the car in neutral? Sounds like PB & neutral would be better than PB & P?
Yes...me too...as I posted earlier, I was able to turn it off on both of our Subaru's...and my son was able to do the same on his 2015 Mustang. Configurable on the settings function for all of them.
Elmer
I'm not a mechanic, but was advised by one years ago to use the parking brake on auto's or manual's. My understanding is that if you leave your auto in Park, don't have the brake on, and someone hits you, it'll shear off some kind of locking pin (don't quote me on that...I'm trying to recall from decades ago).
I see you're down south...here with winter weather, road salt, etc...if you drive a vehicle in those conditions and don't use the brake, it has a much better chance of seizing up.
Hill Assist works when forward facing down a hill, when you're in reverse. Hill Assit takes some getting used to in that you'll kill the engine if you don’t give it enough gas to overcome HA's hold on the car.
That's kinda what I was asking. If I'm in P, and get hit, my transmission will not like that even if I had the EB on. The P in the automatic is a "gear", if you will, and trying to roll the wheels in P will strees the transmission. On a manual, in neutral, with the PB on, nothing in the transmission is engaged and it shouldn't get any stress internally if the car is rolled against the PB.
Sorry to hijack thread but I put the parking break on everytime I park and get out. I live in FL, flat all around. It's an M7, so can I just leave it in gear and call it a day?
Absolutely. I do it all the time....more convenient and saves wear & tear on the parking brake mechanism.
Originally Posted by Elk
What is being referred to is the parking pawl:
I'm going to go out on a limb here, but I'm venturing to say that if you get hit while parked, you're going to have far more problems then shearing off some kind of locking pin.......
I live in flat FL yet ALWAYS apply the parking brake with any manual transmission. In order to start the car you have to clutch in, so even the slightest incline (like my driveway) and it will start rolling. Sure you can hold the regular brake but I learned to drive when cars required a little gas to fire up and you run out of feet if all 3 pedal are required To me a manual is only "in park" when the e-brake is engaged.
Yeah, old habits die hard! The C7 will fire up just fine with no accelerator input.
I'm sure you don't do this, but it makes me cringe when I hear someone immediately rev a dead-cold engine on startup. Automotive equivalent of nails on a chalkboard!!
Let me clarify something about this post. In light of the advise you got, do you then always place your AT vehicles in Neutral when parking them? Just wondering?
