Know issues?
Old Jan 29, 2022 | 12:12 PM
Ralphp's Avatar
Ralphp
Even though first year of the C7, the 2014 is arguably the most trouble-free of the six year model run. If I get another, it will be a very low mileage and immaculate 2014.
Consumer Reports gave the 2014 the best score for reliability of all C7s.
Old Jan 29, 2022 | 03:30 PM
Skid Row Joe's Avatar
Skid Row Joe
Originally Posted by LS1AB
I’m thinking about getting a 2014 Z51 M7. Are their any known issues I should look for or be concerned about?
Get the GMVIS report on the car from a Chevrolet or GM dealer.
Old Jan 29, 2022 | 03:34 PM
Skid Row Joe
Originally Posted by 449er
The 2014 model year is a pretty reliable, go get it
It has known frequently reported issues. Best bet is the 2019 of the series.
Not necessarily. I'd argue that the 2017 is more trouble free than the 2014.
Old Jan 29, 2022 | 05:37 PM
Ralphp's Avatar
Ralphp
Originally Posted by joemessman
Check the info screen. Some were flaky. Check for a roof rattle. Drive it over a semi-bumpy road.
Thank's for those tips, I'm test driving a 2016 C7 Z51 Thursday.
Old Jan 29, 2022 | 05:43 PM
Ralphp's Avatar
Ralphp
Am I understanding correctly that the GMVIS will show only service and repairs at a GM dealer? If a repair was done at a local shop it would not be noted?
Old Jan 29, 2022 | 11:04 PM
Skid Row Joe
Correct.
You can/should also check Carfax too. Carmax uses a different service than Carfax though.
Old Jan 29, 2022 | 11:17 PM
Ralphp's Avatar
Ralphp
Correct.
Thanks Joe. I see Carmax uses a service from Experian.
Old Jan 30, 2022 | 05:21 PM
Mayor111's Avatar
Mayor111
Sorry but both of your statements are just not true. 2014 has been documented in so many automotive magazines and talked about over and over on so many automotive shows, to be the most reliable year...actually I can't remember a time when anyone ever challenged that...except you.
Old Jan 30, 2022 | 10:24 PM
Skid Row Joe
So document away then, if my statements are so wrong?? You're saying the 2019s are lemons??
If given a choice I'd go for the C7 2019 EVERY TIME! Not sure what's so difficult to understand about that.
Old Jan 31, 2022 | 12:07 PM
miami08VETTE's Avatar
miami08VETTE
I agree with this point of view! In my experience with automobiles over the years the last run of a Generation tends to be most reliable since they've had time to work out most kinks. Admittedly not always the case...
Old Aug 15, 2022 | 01:53 PM
BevHirz's Avatar
BevHirz
Was there a fix on the last item that you listed re going into 4 cylinder mode?
I am looking at buying a 2014 Z51 and trying to look at all issues. Vehicle is at 45k miles
Thanks for a reply....
Old Aug 15, 2022 | 02:00 PM
BevHirz's Avatar
BevHirz
Great question as I am about to buy a 2014 Z51
Old Aug 15, 2022 | 02:17 PM
  #33
Bill Dearborn's Avatar
Bill Dearborn
There is at least one issue that hits some owners. The 2014s have an issue where the cooling fan will stop functioning which will cause the car to overheat in traffic. The quick solution is to turn the engine off and back on and that usually starts the fan operating again. After that, it might be months before the fault occurs again. The permanent solution is to upgrade to the 2015 Z06 600-watt fan which is a GMPP performance part for the 2014 cars.
Bill
Old Aug 15, 2022 | 03:47 PM
  #34
joghotrod's Avatar
joghotrod
Bill
Does the 2014 Z51 come with the better fan? If not that will be a future upgrade for my car.
Jimmy
Old Aug 16, 2022 | 09:51 AM
  #35
JMII's Avatar
JMII
The M7 only uses 4 cylinders when put into Eco mode. For the automatics you need this: https://www.rangetechnology.com/
Old Aug 16, 2022 | 11:31 AM
  #36
BevHirz's Avatar
BevHirz
Yes I did that but I have been told over and over to come to this site for more info than posted in Google or other social media.
Thank you for your response.
Old Aug 16, 2022 | 12:18 PM
  #37
Rayland's Avatar
Rayland
Banned Scam/Spammer
OP:
"8 out of 10 Americans want Apple CarPlay in their next car."
(Only consider 2016's or newer.)
Many thanks,
Ray
To Know issues?
Old Aug 16, 2022 | 04:15 PM
  #38
JMII's Avatar
JMII
It can be retrofitted with some minor limitations to the older cars... but its not cheap at about $1k.
Old Aug 16, 2022 | 09:45 PM
  #39
Maxpowers's Avatar
Maxpowers
OP:
Many thanks,
Ray
I would assume 8 out of 10 want Apple Carplay or Android Auto given 8 out of 10 Americans dont have iPhones. But your point is valid in terms of syncing the smart phone.
Old May 2, 2023 | 05:29 PM
  #40
Plasticpig's Avatar
Plasticpig
Was the Z06 fan assembly a drop in fit? i.e. all the bolt holes in the same place? Thanks in advance for your reply, Mike McElroy
