outer rear trunk release button not working
Old Jan 31, 2022 | 05:27 PM
Theinvid75's Avatar
Theinvid75
2nd Gear
Default outer rear trunk release button not working
So, I have not been successful in finding a fix in the forums for my issue. The outside rear trunk release button located near the license plate used to work but no longer functions. I have the fob (with new battery installed a couple months back). I have the fob on me in my pocket when I try to use it. I have tried using the manual key hole near it to open the trunk then reclose it and test the button...still nothing.
The vehicle is an m7 and is turned off in neutral with e-brake on.
Any ideas?
Yes, the trunk release button near the steering wheel works as well as the button on the fob for the trunk.
thanks in advance!
Old Jan 31, 2022 | 05:45 PM
iclick's Avatar
iclick
Have you had any work done in the rear of the car that requires removing the bumper cover? If so, the connector linked to the switch may have not been properly re-connected. If not, you may have a bad switch. Did it ever work?
The trunk-release mechanism, including the key function, works which I think points to the switch itself. The rear bumper isn't hard to remove, so in the absence of any other ideas offered by others you may need to do that to access and test the switch.
Old Jan 31, 2022 | 06:08 PM
Theinvid75's Avatar
Theinvid75
2nd Gear
The rear bumper was removed during the wrap process but the button worked both before then and after that for months.
Old Feb 1, 2022 | 12:48 AM
Grand Slam's Avatar
Grand Slam
A couple of thoughts:
Put your fob near the driver's door to ensure your 'new' battery is not the problem. Some new batteries are weaker than our cars like and some are downright DOA (not your problem).
Many people have trouble using the key in the back so don't assume that is part of the same problem.
Old Feb 1, 2022 | 02:36 AM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
My key fob key turns the lock and the hatch pops up, but the latch is hung up and is not releasing.
Battery is dead. I'm locked out.
Anyone have a solution?
Old Feb 1, 2022 | 01:01 PM
Grand Slam's Avatar
Grand Slam
From you newest description it looks like you have the same problem as this other thread so check it out: https://www.corvetteforum.com/forums...ocked-out.html
Old Feb 1, 2022 | 03:27 PM
c5arlen's Avatar
c5arlen
Neophyte Design Group strkes again!
To outer rear trunk release button not working
