Change oil or wait?
I had my oil tested prob 25 times in various 911's. I changed it around 6-8k kms and that was usually at least once a year but if it wasnt at the end of the year, then I went by mileage as Porsche recommends
Under normal operating conditions and at 8k km intervals, the analysis always indicated that there was plenty of life left in the oil.
Thanks. That is a very good thing to know.
I have a more philosophical argument with these so-called line in the sand maintenance schedules. Porsche and GM have very different requirements with what is essentially the same oil. And I doubt many would argue that the flat 6 has less tolerances than the v8 and therefore its ok to go for longer intervals
It just doesnt make sense. A modern synthetic, under normal high performance operation, does not breakdown to the extent that it NEEDS to be changed after 1 year if its got 1k miles on it
The OLI will tell you to change oil after one year, and you didn't follow their plan. If you reset it without a change, you'll need to fake proof that the change was done.
A similar topic came up back in the C6 days when people would get a tune on the ECM. If GM found out about it (usually when you go for some expensive warranty repair), they immediately and permanently blocked your powertrain warranty. Even if the tune had nothing to do with your problem, they didn't care. Tune = no warranty.
Sure you can fight them in court. They don't want your case to set a precedent, so they'll drag out all their experts to show why the warranty deniable was reasonable.
In the end, you'll spend more money on lawyers than the cost of a new engine, and probably lose.
It's like the cracked wheel problem on the GS/Z06. GM will fight tooth and nail to avoid paying for something that exposes them to further expense. Even though the cracked wheels seem to us like an obvious defect, GM has been successful in 99% of the court cases.
In OP's case, I'd get the change done ASAP. Have them take two samples from the old oil, send one to a reputable lab for analysis now and save the other one in case GM ever wanted to do their own analysis.
With the low miles and relatively short time past the one year limit, probably GM will not get tough with him if he has a problem in the future, especially since it looks like an honest oversight. If they bring up the year limit some day, be nice and contrite and offer to share the oil analysis results.
In big warranty claims, GM makes the decision and not the owner or the dealer. But a dealer that likes you can advocate for you and sometimes sway the decision. Our local dealer went to bat for me on a warranty issue and GM covered it, even though they didn't have to.
And if you get a tune thats a lot different than changing your oil at 18 months vs 12. I would expect my warranty to be immediately denied if I got a tune and why my 911 was already out when i did get one
Of course GM (or Porsche, see IMS and bore scoring issues) will do whatever they can to avoid paying out but does anyone have an actual example of a warranty being denied in a situation like this??
I recall stories of guys getting warranty denied for a non-original PCM program, and GM said they absolutely didn't care what what was in the program. The mere fact that GM could tell that a non-stock program had been there some time in the past, was an automatic denial. I agree that most tunes deserve a warranty denial, but some of the stuff was really innocuous; made no difference.
The real point is that we don't want to give GM any grounds for warranty denial, no matter how tenuous.
Exactly. Call it paranoid but it's so cheap to be safe and not have to squabble with them.
I've been faithfully following the manual for these first five years, including the use of PF64 filters, which althought these aren't the world's best will cover me on any filter related questions. Use Brand X, no matter how good it is, jeopardizes your position in any warranty question that might involve the filter.
Has anyone done a lab test at Blackstone or elsewhere when using Mobil1 5w30? Actually, any Dexos-rated oil would be close enough. Seeing the test results would help us to make a judgement on how far we can safely go.
One of our Canadian members went about 2 years between some changes, and the results weren't worrisome. But that was in a more ordinary car, not a Corvette.
